NP242 - Shifter Tab length - JeepForum.com
post #1 of 17 Old 05-07-2013, 06:45 PM Thread Starter
smcalpac
I've searched the conversion page so many times my eyes are spinning and I've tried looking through the numerous pages that come up with the search feature.
I am ready to swap in a NP242 to replace my 249. The donor transfer case didn't have the shift tab. I know the 249 tab is longer so I can fab it to make it work.
Question being, can anyone tell me what the measurement is from center to center for the tab on the NP242? From the mounting shaft/nut at the case to the center of the hole for the shift linkage?
A bit more advanced perhaps is does anyone know if the indexing (position of the tab on the transfer case) is the same on both the NP242 and NP249?
My sincerest thanks to any one that can assist!
I'm here because
my little girl
doesn't need her dad
on two wheels anymore!
Camoflauge, camoflauge, I disappear when I pull out of my garage!
PM me for LED light bars and HID off road lights
smcalpac is offline
post #2 of 17 Old 05-07-2013, 07:24 PM
ejschultz
ejschultz's Avatar
For simplicity's sake, I'd say go to the JY and get a tab off a 242. IIRC, it's about an inch shorter than the 249. I'd go out and measure mine for you, but work sent me to the middle of Ohio for a job. Sorry.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Trail Gear front bumper, 31" Duratracs on 15x8s
ejschultz is offline
post #3 of 17 Old 05-07-2013, 08:34 PM Thread Starter
smcalpac
I hear ya. Unfortunately JYs aren't in my schedule. Much easier for me to fab off of my existing tab actually if I had the length. I won't be doing the swap till next weekend so I have time. Just like to have my ducks in a row so to speak.
I'm here because
my little girl
smcalpac is offline
post #4 of 17 Old 05-08-2013, 05:26 AM
ejschultz
ejschultz's Avatar
I hear ya. I'll be home Saturday. If someone doesn't measure one for you by then, I'll see if I can get up there without pulling off my skid to get the measurement for ya.
post #5 of 17 Old 05-08-2013, 11:24 AM Thread Starter
smcalpac
Highly appreciated if you or any one else could!
I'm here because
my little girl
smcalpac is offline
post #6 of 17 Old 05-08-2013, 11:54 PM
shaban
Will measure mine tonight. Have a 242 on my shelf ready to replace my 249 when I've got time and motivation
shaban is offline
post #7 of 17 Old 05-09-2013, 12:39 AM Thread Starter
smcalpac
You're a gentleman and a scholar. I can't thank you enough!
I'm here because
my little girl
smcalpac is offline
post #8 of 17 Old 05-09-2013, 05:27 AM
shaban
Some photos:
The slot appears to be at 45 degrees to the tab.
Distance between the threaded stub and the link center is a bit more than 1 3/4 (maybe 1 25/32)
Overall tab length about 3''
Hope this helps
shaban is offline
post #9 of 17 Old 05-09-2013, 11:17 AM Thread Starter
smcalpac
Shaban, I can't thank you enough! Perfect, above and beyond!
I owe you a beer or three!
I'm assuming the transfer case is in 2-hi position pictured?
I'm here because
my little girl
smcalpac is offline
post #10 of 17 Old 05-09-2013, 12:14 PM
lil_joe
Just did this swap, and you need to be prepared for some modifications to the linkage rod that connects at the T-case, took me 3 hours to get it to shift into all positions
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
lil_joe is offline
post #11 of 17 Old 05-09-2013, 01:32 PM Thread Starter
smcalpac
Any words of advice other than what's posted in the sticky? I'm expecting to have to go through and adjust the linkage length, etc.
I'm here because
my little girl
smcalpac is offline
post #12 of 17 Old 05-09-2013, 01:51 PM
lil_joe
I'll PM you
Mike
____
lJeepl
--[.]IIIII[.]
lil_joe is offline
post #13 of 17 Old 05-09-2013, 05:00 PM
shaban
Not sure about the position. I've rotated the tab clockwise all the way to clear the front yoke, so I think it was in 4LO.
shaban is offline
post #14 of 17 Old 05-09-2013, 06:00 PM Thread Starter
smcalpac
lil joe, I'll keep an eye out for it. Appreciate any info you can supply.
shaban, makes sense. I recall the most forward position being 4-lo.
I'm here because
my little girl
smcalpac is offline
post #15 of 17 Old 05-10-2013, 05:04 AM
ejschultz
ejschultz's Avatar
Install the transfer case with it in neutral, shift the tab back by hand before the linkage is connected to it to 4 low, loosen the "set bolt" that locks the adjustment for the linkage, connect the linkage, move the shifter into 4 low, and tighten. With the help of a buddy under my ZJ, it took me 10 minutes to work the shifter to get it properly adjusted. There are plenty of threads on here for doing so.
