NP242 Full Time 4WD feels like Part Time - Page 3 - JeepForum.com
post #31 of 34 Old 09-19-2013, 06:02 PM
shaban
Actually, both axles are supposed to be the same, it's going to bind hard and overstress the drivetrain otherwise. All 4WD's have the same ratio back and front, and also thats why you're supposed to have all 4 tyres same size (at least on 249 tcase).
Check the tags with numbers on both differentials, first 3 numbers on second row tell the ratio (355 stands for 3.55, 373 for 3.73)
shaban is offline
post #32 of 34 Old 09-19-2013, 06:32 PM Thread Starter
kb9mfd
That is what I thought, but I heard different before. Both of them start with a 55 on the second line, They are rather hard to read. - Jeremy
kb9mfd is offline
post #33 of 34 Old 09-19-2013, 11:34 PM
shaban
Well, you could use a metal brush to scrape these tags a bit if you want, often the first digit is under a bolt head.
Heres what my front one off an XJ said (it's a 3.55) :
52069199
3.55 610504-7
3.55's are somewhat unusual for ZJ's, they're mostly 3.73 as far as I know.
Heres one photo of a tag, not mine though:
shaban is offline
post #34 of 34 Old 09-20-2013, 05:33 AM Thread Starter
kb9mfd
Well, being I can read the "55" I assume the 3 is under the bolt head. Both would be the same so I guess that is not an issue. From what I googled, the '95 with a I6 3.55 was the most popular, with 3.73 used in the V8 and towing packages. Maybe I will just have to take that TC apart and see if there is a reason it gets stuck in PT. maybe there is some uneven wear that causes it not to shift out when it is bound, or a spring is bad. - Jeremy
kb9mfd is offline
transfer case
