NP242 Full Time 4WD feels like Part Time - JeepForum.com
post #1 of 34 Old 08-31-2013, 03:35 PM Thread Starter
kb9mfd
I have not had a NP242 before, but when I put it in Full Time 4WD the front binds and learches on tight corners. (like in a parking lot or a turn). I know that is an issue with Part Time, but I did not expect it on Full Time. Honestly when in either mode it drives the same, and both lurch when turning. I know it's in Full Time (the dash says so). Also I have issues trying to get it back in 2WD after going 4WD. It takes seveal tries before It disengages the 4WD. The dash says 2WD, and the lever is all the way down, but it is behaving like it is in Part Time 4WD. I have to shift all the way to N and then push as fast as I can forward to 2WD (Stopped and transmission in N also) and try to drive and see if the lurching goes away. It feels like it shifts, but it is not actually disengaging the 4WD. Any suggestions? Thanks! - Jeremy
kb9mfd is offline
post #2 of 34 Old 08-31-2013, 04:44 PM
gmtech22
You got different sized tires front and back? That can make it take several yards before it disengages completely. Might also want to get a novak shifter.
gmtech22 is offline
post #3 of 34 Old 08-31-2013, 05:38 PM Thread Starter
kb9mfd
No, they are all the same. I was under the impression that these transfer cases (the NP242, NP231, etc..) were direct shift like a manual transmission. I assumed when I went into a gear, that is what it is in. So when I shift it, it actually may take a while before it completely engages/disengages after shifting?
kb9mfd is offline
post #4 of 34 Old 08-31-2013, 06:04 PM
Technohead
Originally Posted by kb9mfd View Post
. . . I know it's in Full Time (the dash says so). . .
That right there is funny.
I've found 242's to be quite sensitive to linkage adjustment because there are so many positions. The first step I always take is to disconnect the linkage from the t-case and manually cycle the t-case through the different positions. If the problem persists then something is hosed inside the t-case.
And oh yea . . . don't trust those silly indicators on the dash.
-Eric
Technohead is offline
post #5 of 34 Old 08-31-2013, 07:45 PM
Mickey_D
Wouldn't make a bit of difference in Full Time. The NP242 has a differential between the front and rear outputs in Full Time. You could quite literally block the front wheels from turning and lift the rear end and the rear wheels would spin freely.
Only when you engage Part Time does the transfer case force both outputs to spin in unison.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #6 of 34 Old 08-31-2013, 08:34 PM Thread Starter
kb9mfd
I just put it in a month ago, and when I had it out I did that to make sure it was going in all posistions. I have adjusted the linkage a couple of times since too. I also have found the "stop" on the shift is in the incorrect position for 4WD Full, I have to pull it sightly past it to feel the "bump" of being in that position and for the indicator to show Full Time. (I could cut the "stop" out) I guess I figured if the indicator was showing I must be there since I have to guess where that posistion is. If I configure it to be at the stop for Full, then I can never get it back into 2WD, I have to adjust it for 2WD (and then it still gives me trouble, I guess I will have to adjust it again) but then pull past the stop for Full. I do not seem to have any issues with low (although I have only tried it once to make sure it worked.) or N. After getting things put back together and before I got it off the blocks, I did go threw all the ranges a couple of times and watched the tires spin and used the emergency brake to test the Full 4WD and it did work. (braked the rear and the front spun, in part time nothing spun with the brake) - Jeremy
kb9mfd is offline
post #7 of 34 Old 09-02-2013, 01:24 PM
dougmorgan99
After my 242 swap I get the same issue you describe trying to shift back into 2WD. No adjusting of the linkage worked. Nor did shifting rolling backward, etc as others described. I actually can switch into all modes when everything is cold. I am at the point that if I use 4WD, I let it sit overnight then shift into 2WD in the morning.
There is a thread I haven't tried yet to try and fix my 242 shifting issues... maybe it will help you?
http://www.jeepforum.com/forum/f13/2...e-fix-1225426/
dougmorgan99 is offline
post #8 of 34 Old 09-02-2013, 01:47 PM
capcyclone
capcyclone's Avatar
I have a 249 and when I shift into 4lo I definitely "feel it" engage and can tell as I'm driving, but I've often thought of getting it up on jack stands and shift into 4lo - I've never done it, but I assume you'd be able to visually confirm you are getting power to all 4 wheels - right?
"The Jeep is America's only real sports car" - Enzo Ferrari
'98 Jeep GC 5.2L "ZJ" - Sold
'02 Jeep GC 4.7L HO "WJ" - Daily driver
capcyclone is offline
post #9 of 34 Old 09-02-2013, 01:49 PM
PolkaPower
Sounds like it's time to swap in a 249.
PolkaPower is offline
post #10 of 34 Old 09-02-2013, 01:58 PM
dnuccio
if you need an idiot light to tell you what 4wd mode youre in, you shouldnt own a jeep IMO
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #11 of 34 Old 09-02-2013, 03:12 PM
capcyclone
capcyclone's Avatar
Let's cut the OP some slack. Besides the comment about the dash indicator - I can sort of understand his question. If he isn't "feeling" the engagement as he shifts his TC, it does make it difficult to know for sure.
post #12 of 34 Old 09-02-2013, 03:48 PM
ZJfamilyfun
My 242 swap went well. I too have the disengage back to 2wd issue. Its sensitive. It takes a few trys. I did have the same issue with my 87 xj that had the 242 stock. As for full time feeling like part time, i would suggest shaking down the front end and checking tire pressure. My full time is amazing! I'll use it when it rains to prevent sitting at stop lights burning rubber. Turns like its in 2wd. But i'll still use it on moderate trails, when 4wd isnt needed the whole time. I love it!!! I dont think i'll ever use a 231 again. Just my opinion. Check/change the fluid. When it works its great! Good luck.
ZJfamilyfun is offline
post #13 of 34 Old 09-03-2013, 05:29 AM Thread Starter
kb9mfd
Thank you for the link, I will look into that. - Jeremy
kb9mfd is offline
post #14 of 34 Old 09-03-2013, 05:33 AM Thread Starter
kb9mfd
I was using it to confirm the transfer case internals where in the righ mode and my linkage working. If the light is on I know internaly I have the shift arm centered in its position. - Jeremy
kb9mfd is offline
post #15 of 34 Old 09-03-2013, 05:42 AM Thread Starter
kb9mfd
Thank you. No I am not feeling the TC engage or disengage when it does, I notice it when making corners. It so far it has not shifted to 2WD on the fly. (no issues with PT, I am not sure if I have ever got it in FT, FT drives like it is in PT) I just checked the fluid, its good. So far I have only got it to actually go back to 2WD if I put both the transmissiton and TC in N, let it roll back than then shift the TC into 2WD. That so far has worked 50% of the time. (leaving the transmission in N) - Jeremy
kb9mfd is offline
transfer case
