NP231 vs. NP242 vs. NP249 - JeepForum.com
post #1 of 29 Old 03-20-2007, 12:07 PM Thread Starter
offroader156
How much lower does an NP242 and an NP249 hang down than an NP231?
offroader156 is offline
post #2 of 29 Old 03-20-2007, 12:10 PM
nierace
nierace's Avatar
2003 WJ
Are you sure it hangs lower ?
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #3 of 29 Old 03-20-2007, 12:13 PM Thread Starter
offroader156
I was looking at TC skids on Rusty's and it says on the site that you need a different skids for different TCs.
post #4 of 29 Old 03-20-2007, 12:14 PM Thread Starter
offroader156
It says NP242 skids have a "ed.-bend" to make room for the NP242 TC.
post #5 of 29 Old 03-20-2007, 01:16 PM
li'l jeep
Always a Pirate
li'l jeep's Avatar
they shouldn't be lower...i think its just a different crossmember for the mount
1997 ZJ Ltd. 5.2L V8
2003 WJ Ltd. 4.7L V8
GOD BLESS AMERICA!
li'l jeep is offline
post #6 of 29 Old 03-20-2007, 05:34 PM
Trouble Maker
reckless endangerer
Trouble Maker's Avatar
The front output shaft area of the 242/249 case is slightly larger than the 231 case.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline
post #7 of 29 Old 03-20-2007, 05:59 PM
jfowlzj95
Not sure with the 242, but the 249 hung a little lower than the 231 I swapped in. Was only about an inch. The 249 is definatly more bulky than the 231 though lol.
95 zj with some big n heavy crap!
jfowlzj95 is offline
post #8 of 29 Old 03-21-2007, 07:12 AM
li'l jeep
Always a Pirate
li'l jeep's Avatar
Okay just to be sure...cause i always forget and get confused, the 242 is selc-trac, the 249 is quadra-trac (4wd only) and the 231 is the command-trac?
GOD BLESS AMERICA!
post #9 of 29 Old 03-21-2007, 07:22 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
you got it
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #10 of 29 Old 03-21-2007, 08:55 AM
li'l jeep
Always a Pirate
li'l jeep's Avatar
okay with that straight...i don't like not having a 2wd option...i just like to have more control of my options. anyway, what would be involved in switching from a 249 to a 242 and how easy is it to get my hands on a 242? it'll be a switch down the road but prolly will definately happen
GOD BLESS AMERICA!
post #11 of 29 Old 03-21-2007, 09:05 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
i would say search for it because so so many people have done it, but the search will omit "242" and "249". you can pretty much get any 242, the drive shafts just have to have the same spline count, so you may need a shaft or two from the vehicle you take the 242 out of. Also, you may have to take the shells apart because the front half of the cover of the new 242 might not bolt up so you have to use the half from your 249. just a couple common swap problems...
post #12 of 29 Old 03-21-2007, 09:07 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
think of the 242 as all the options the 231 and 249 has put together. correct me if im wrong, but with the all time 4WD on the 242, you cant use it at all speeds so it isnt exactly the same.
post #13 of 29 Old 03-21-2007, 09:11 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
You can use full-time at any speed. You're just supposed to shift into/out of the 4wd options below 55mph.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #14 of 29 Old 03-21-2007, 09:12 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
oh i got mixed up. i want a 242 now!
post #15 of 29 Old 03-21-2007, 09:14 AM
li'l jeep
Always a Pirate
li'l jeep's Avatar
i think on the 242 there is a "part" and "full time" 4 wheel drive. the full time should be the one you can use at highway speeds...its for wet pavement and the such, on my dad's XJ thats what he uses for snow ice and rain, and im pretty sure thats 4 the higher speeds...if i did have that i wouldnt be going over 70 on it anyway.
if that "full time" is the same as my 249's AWD (4 all time as it reads on the bezel) its okay for speeds past 120 mph thats been proven by me....lol
GOD BLESS AMERICA!
Transfer Case Swap Info NP249->NP231 & NP242 JrMechanic ZJ Grand Cherokee Forum 3441 08-22-2017 09:16 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
How do I swap a NP249 for a NP242? FoxriderUTI ZJ Grand Cherokee Forum 1 10-01-2009 06:45 PM
NP249--Np242 swap capone518 ZJ Grand Cherokee Forum 3 05-21-2008 10:13 PM
NP249 to Np242 Rcher ZJ Grand Cherokee Forum 7 05-31-2005 11:47 AM
