-   -   NP231 vs. NP242 vs. NP249 (http://www.jeepforum.com/forum/f13/np231-vs-np242-vs-np249-390712/)
offroader156 03-20-2007 12:07 PM
How much lower does an NP242 and an NP249 hang down than an NP231?
nierace 03-20-2007 12:10 PM
Are you sure it hangs lower ? :confused:
offroader156 03-20-2007 12:13 PM
I was looking at TC skids on Rusty's and it says on the site that you need a different skids for different TCs.
offroader156 03-20-2007 12:14 PM
It says NP242 skids have a "ed.-bend" to make room for the NP242 TC.
li'l jeep 03-20-2007 01:16 PM
:agree: they shouldn't be lower...i think its just a different crossmember for the mount
Trouble Maker 03-20-2007 05:34 PM
The front output shaft area of the 242/249 case is slightly larger than the 231 case.
jfowlzj95 03-20-2007 05:59 PM
Not sure with the 242, but the 249 hung a little lower than the 231 I swapped in. Was only about an inch. The 249 is definatly more bulky than the 231 though lol.
li'l jeep 03-21-2007 07:12 AM
Okay just to be sure...cause i always forget and get confused, the 242 is selc-trac, the 249 is quadra-trac (4wd only) and the 231 is the command-trac?
QuadraTokn 03-21-2007 07:22 AM
you got it :thumbsup:
li'l jeep 03-21-2007 08:55 AM
okay with that straight...i don't like not having a 2wd option...i just like to have more control of my options. anyway, what would be involved in switching from a 249 to a 242 and how easy is it to get my hands on a 242? it'll be a switch down the road but prolly will definately happen
QuadraTokn 03-21-2007 09:05 AM
i would say search for it because so so many people have done it, but the search will omit "242" and "249". you can pretty much get any 242, the drive shafts just have to have the same spline count, so you may need a shaft or two from the vehicle you take the 242 out of. Also, you may have to take the shells apart because the front half of the cover of the new 242 might not bolt up so you have to use the half from your 249. just a couple common swap problems...
QuadraTokn 03-21-2007 09:07 AM
think of the 242 as all the options the 231 and 249 has put together. correct me if im wrong, but with the all time 4WD on the 242, you cant use it at all speeds so it isnt exactly the same.
ArloGuthroJeep 03-21-2007 09:11 AM
You can use full-time at any speed. You're just supposed to shift into/out of the 4wd options below 55mph.
QuadraTokn 03-21-2007 09:12 AM
oh i got mixed up. i want a 242 now! :mad: :laugh:
li'l jeep 03-21-2007 09:14 AM
i think on the 242 there is a "part" and "full time" 4 wheel drive. the full time should be the one you can use at highway speeds...its for wet pavement and the such, on my dad's XJ thats what he uses for snow ice and rain, and im pretty sure thats 4 the higher speeds...if i did have that i wouldnt be going over 70 on it anyway.
if that "full time" is the same as my 249's AWD (4 all time as it reads on the bezel) its okay for speeds past 120 mph thats been proven by me....lol
The time now is 12:24 AM.
