NP 249 NP 242 Swap 94 ZJ 5.2 Trans Case swap / repair?
#1 | |
Got a transfer case goin out in my ZJ. I wanted to put in the NP 242 and I heard that 94 is the split year where it might and might not bolt up. Is there a way to know if I will have to tear that case apart and put the old NP 249 input shaft in? I didnt want to put an old shaft in a brand new case because I dont think that will work well correct? Any help would be great. I've alredy had the case apart to rebuild the viscous but the rear drive shaft broke off the differential and cracked the t case. anyone also know how to possibly dissassemble the tail housing off the np249? do i need special tools? certain precedure? Thanks for your help! email: smkarner@mtu.edu if you want.
Steve
#2 |
GSMW!
Check THIS write up out for the TC swap
-Tim GS-MW 2009 INFO KD8EBC '94 ZJ 5.2 LTD Project TORTOISE Build-up thread JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
