Nothing but Heat! - JeepForum.com
post #1 of 10 Old 12-19-2002, 08:50 AM Thread Starter
davejr38
Nothing but Heat!
Help! I have nothing but heat! Compressor engages. No matter what I set the temp at, it blows out constant heat (same temp). Fan speed works OK. Any help we I can begin? Its a 96 Jeep Grand Cherokee Larado Limmited.
davejr38 is offline
post #2 of 10 Old 12-19-2002, 09:01 AM
zrexron
Me too?
My compressor will not engage. It'll be interesting to hear what you find out. I can bypass the low pressure switch and the compressor clutch will kick it in, but so far I don't know if it's the switch or a freon/134 leak.
BTW: heat-only is a good thing around here this time of year. :-)
zrexron is offline
post #3 of 10 Old 12-21-2002, 12:26 PM
MJR
MJR's Avatar
1988
Re: Nothing but Heat!
Does one of the A/C lines get cold ?. If not then you have a leak and are low on Freon. If when you turn the temp knob and the temp doesn't change at all then you might be a blend air servo.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #4 of 10 Old 12-21-2002, 12:28 PM
MJR
MJR's Avatar
1988
Re: Me too?
You can look at the A/C lines to look for oil wetness. It depends on the year and engine as to what is most common for leaks.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #5 of 10 Old 12-22-2002, 08:49 AM
Stocker
Maybe I'm missing something here , but on at least some vehicles, you set the temperature with a knob, lever, or whatever, which controls a valve, usually in the heater hose. This changes the amount of hot water flowing through the heater core. If the valve (or the knob, lever, linkage etc) fails, you may get no heat (if the valve is stuck colsed), or nothing but heat (if the valve is stuck open). Regardless of whether the A/C compressor is engaged or not.
My guess is a failed water control valve. Had it happen on my old pickup.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #6 of 10 Old 12-23-2002, 12:51 PM
MJR
MJR's Avatar
1988
Grand Cherokees do not have a heater valve. The control head uses a servo motor to move the temp door on all Grand Cherokees which adjusts between the hot and cold sides to get the temp selected (blend air system).
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #7 of 10 Old 12-23-2002, 04:32 PM
Stocker
Aha! Never too old to learn something! Thanks for the info.
Stocker
Stocker is offline
post #8 of 10 Old 06-30-2003, 02:53 PM
automan25
So does this mean that there is hot coolant always circulating through the heater core?
Is this why all the plastic pieces underneath the dashboard on the passenger side are always radiating heat into the vehicle?
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #9 of 10 Old 07-01-2003, 12:02 AM
MJR
MJR's Avatar
1988
Yes the heater core always circulates coolant.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #10 of 10 Old 07-01-2003, 10:01 AM
automan25
I noticed yesterday that CSKauto (Shucks, Kragen, Checker) sells a manual heater control valve for the Jeep Grand Cherokee. I may pick one of these up and install it to see if it reduces the amount of heat in the passenger compartment. My biggest concern with it though, is that it may cause the engine to run hotter.
99 WJ with manual ac/heat controls blows heat then turns cold GA350 ZJ Grand Cherokee Forum 10 01-04-2009 09:59 PM
I need more heat jeepin4evr ZJ Grand Cherokee Forum 4 10-08-2008 03:12 PM
No Heat!! justjeepin ZJ Grand Cherokee Forum 3 10-06-2008 04:58 AM
Manual Heat Only (No Auto Heat) FFuries ZJ Grand Cherokee Forum 0 09-27-2008 05:25 PM
Blend Door Woes! No Heat! No Heat What so ever 3 ERROR CODES! Polaris Junkie ZJ Grand Cherokee Forum 4 09-20-2006 10:05 AM
