Not the Death wobble but something similar. - JeepForum.com
post #1 of 9 Old 12-19-2011, 11:58 PM Thread Starter
JeepGypsy
1994 ZJ
I've been reading and watching videos on the death wobble and it seems to me that the death wobble is a bit more violent then what is happening with my Jeep. So i drive a 94 ZJ and a few moths ago she began to shake when i would accelerate from about 15-50 mph and then smoothes out. I also have noticed that the more weight I have in the Car the worse the shacking is, but its not violent like the shacking in the videos i have been watching. could this be my transfer case, front or rear diff, transmission, or something thats just loose?
JeepGypsy is offline
post #2 of 9 Old 12-20-2011, 12:08 AM
awmiller
if you have All time 4x4, the CV joint could have gone bad in the front and that causes something very similar to a death wobble
awmiller is offline
post #3 of 9 Old 12-21-2011, 11:02 PM Thread Starter
JeepGypsy
1994 ZJ
ya I do have all time 4wheel drive and I have also noticed a burning smell each time I get out of the jeep which some of the other threads have mentioned in regards to the CV joints going bad. Is there any way to observe the CV joint easily or do I just need to get in there and remove the hub?
post #4 of 9 Old 02-28-2012, 12:40 AM Thread Starter
JeepGypsy
1994 ZJ
So I've replace both of the front CV axels and the shaking is still there, Ive had my U-joints checked, the hubs seem fine, had the tires balanced and had the alignment done. Im thinking it may be my tie rods. any suggestions on what i should look into next?
post #5 of 9 Old 02-28-2012, 01:40 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Follow the same diagnosis cycle a you would for any other death wobble.
Dry steering test, track bar, ball joints, control arm bushings, alignment, tire balance, motor mounts.
ratmonkey is offline
post #6 of 9 Old 02-28-2012, 06:54 PM Thread Starter
JeepGypsy
1994 ZJ
I had my buddy go for a drive with me who had the DW in his Jeep last year. He said its not nearly severe enough and that it was most likely the drive shaft or possibly an engine mount. And what is a dry steering test?
post #7 of 9 Old 02-28-2012, 07:10 PM
squazz
lay under the front of your jeep have a buddy see-saw the steering wheel see what moves that aint suppose to
squazz is offline
post #8 of 9 Old 02-28-2012, 07:11 PM
RedRocket1994
1994 ZJ
Did you get a print-out of your caster/camber/toe numbers before and/or after the alignment? This can be helpful when trying to diagnose DW, too. If camber was off, you might look at ball joints, if caster was off you might look at control arms, so on and so forth.
1994 ZJ, 5.2L/46RH, NP242 & D44HD Swap, 4" SA Lift, 31" KM2s, and all the usual... I only lifted it so I wouldn't have to drive my grandma to church anymore... ;)
Remember: Every time you call a Jeep a "car", God kills a kitten.
Red Jeep Club #657
RedRocket1994 is offline
post #9 of 9 Old 02-28-2012, 07:24 PM
DickDickle
if your alignment was done by a legit shop they would have checked the front end before aligning it, there is no sense aligning a vehicle with bad front end parts
DickDickle is offline
Death wobble WTFisaZJ ZJ Grand Cherokee Forum 6 12-02-2010 09:18 PM
50mph wobble-not death wobble zeekracing ZJ Grand Cherokee Forum 7 07-27-2010 07:58 AM
Death Wobble... Still$$$$$ DenLor ZJ Grand Cherokee Forum 23 06-10-2010 12:21 PM
death wobble. what is it? ronsaun ZJ Grand Cherokee Forum 8 10-05-2009 02:39 AM
35 mph+ I got the death wobble. What could it be? bgky ZJ Grand Cherokee Forum 6 09-22-2005 07:48 PM
