Normal T-Case mount movement - JeepForum.com
post #1 of 4 Old 07-12-2009, 05:13 PM Thread Starter
subeng
So getting under my 2000 Laredo I can grab the rear driveshaft at the transfer case and move the whole tarnsfer case/transmission assembly side to side about an inch and a half to two inches. It does come back to center on its own, mount seems to have springy rubber type resistance, and I can tell there is still rubber in there but is this amount of side to side play of the transfer case mount normal? The service manual isn't very helpful (or I haven't found the right paragraph) as far as amount of normal mount movement or play.
subeng is offline
post #2 of 4 Old 07-12-2009, 08:48 PM Thread Starter
subeng
Anyone?............ I was hoping this would be an easy one. I'll probably end up buying a new mount, it just doesn't seem right to be able to move it back and forth that much.
subeng is offline
post #3 of 4 Old 07-12-2009, 09:02 PM
JBN311
Are you moving the DS?
or the TC?
I'm pretty sure when you yank around on the DS it should hold fast....
-Jesse
2004 WJ Laredo V8, NP242 swapped in, front Dana 30 w/ Vari-Lok, Aussie Locked 44a, BB, 30" BFG A/T's, Tow hooks, Rear Hitch, CB, Better than stock radio/MP3 player.
JBN311 is offline
post #4 of 4 Old 07-12-2009, 09:38 PM Thread Starter
subeng
There is no slack at the slip yoke, the driveshaft is just the most convenient spot to yank the transfer case back and forth. I'll get back under it tomorrow and see if I can tell if the rubber is all cracked or chewed up.
subeng is offline
4x4 mount to transfer case disconnected zjcopper ZJ Grand Cherokee Forum 5 08-19-2009 02:31 AM
rear tranny mount slight play normal? lakailimited06 ZJ Grand Cherokee Forum 3 04-24-2009 07:17 PM
Is it normal for the waterpump and fan to have any movement? 3xX ZJ Grand Cherokee Forum 9 11-26-2008 05:22 PM
Normal to have some back and forth movement in control arms ? jeepunlimited ZJ Grand Cherokee Forum 14 10-17-2007 09:52 AM
Is this movement normal? jeepnurse ZJ Grand Cherokee Forum 3 04-25-2007 04:40 AM
