Noob about Tires/Rim size - JeepForum.com
post #1 of 7 Old 06-23-2013, 02:25 PM Thread Starter
bwatson
1994 ZJ
hey everyone, sorry I've been asking a lot of dumb questions but i'm what you might call "mechanically retarded" and i'm trying to learn. so I'm trying to buy rims for my 94 ZJ and my friend says I need to know the bolt pattern, center bore, and factory offset. what I've found is the bolt pattern is 5x4.5 and the center bore is 71.5mm but I can't find the offset. i'm going to be buying 17x8 rims and try to fit tires that basically measure to about 33 11.2 according to the tire shop. if those don't fit then it's 33 10.5s... can somebody PLEASE tell me the factory offset? any advice/suggestions?
bwatson is offline
post #2 of 7 Old 06-23-2013, 02:41 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Unless you have a limited, the 94ZJs came with stock with 15 x 7 inch rims with 5 x 4.5 bolt pattern with 5.5 inches of backspacing. Your 32 inch tires will not fit into your wheel wells stock. Nor will the 33 x 10s.
Have you looked at the faqs page to see what fits and what doesn't?
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 7 Old 06-23-2013, 02:43 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Backspacing and offset are the same thing using different words.
Most ZJs will run 15 x 8s with 3.75 of backspacing for 32s or bigger.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #4 of 7 Old 06-23-2013, 03:08 PM Thread Starter
bwatson
1994 ZJ
same thing this whole time?! told you i'm a noob haha, thanks. well I have a 4" RC lift that i'm getting installed next week. I was going to buy some 17's and the tire guy said i'll have to bring it in and he'll see what tires he can fit on it.
bwatson is offline
post #5 of 7 Old 06-23-2013, 03:35 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
That paints an entirely different picture.
With the 4 inch lift, the 32s will fit no problem. You'll still need rims with less backspacing that stockers. 3.75 is perfect or even 4 inches.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #6 of 7 Old 06-23-2013, 06:08 PM Thread Starter
bwatson
1994 ZJ
sweet thanks.. when ordering rims do i need to match center bore, offset and backspacing? because almost every wheel i find says 0 offset and 4.5" backspacing and i need -19 offset with 4" backspacing..
bwatson is offline
post #7 of 7 Old 06-23-2013, 06:52 PM Thread Starter
bwatson
1994 ZJ
and my center bore is 71.5mm which comes out to 2.81" and all the rims i'm seeing say 3.27.. going for 17x8 rims if that helps
bwatson is offline
help needed , lift advice , problem , rims , tires
