Noisy power steering pump? Possible quick fix. - JeepForum.com
post #1 of 10 Old 05-04-2007, 08:01 AM Thread Starter
CTCSTrela
CTCSTrela's Avatar
Hey everyone, just as an fyi. My GC had a really noisy ps pump. Whined all the time, hissed, etc. It worked correctly, just loudly.
I flushed the fluid out yesterday, and Omg! It was the nastiest burnt brown crap I've ever seen. I have to assume that the previous owner took it to Jiffy Loooob, or the like, and that they used ATF to refill the PS reservoir. Once I replaced the fluid with mopar standard stuff, the pump was completely quiet again.
Hope this helps someone..
02 WJ Laredo
4dr/4x4
Selec-Track
42RE
60K Miles
CTCSTrela is offline
post #2 of 10 Old 05-04-2007, 11:42 AM
UUJ1
I'm about to try that this weekend, I know my pump works fine, but alot louder than it should be.
UUJ1 is offline
post #3 of 10 Old 05-04-2007, 07:23 PM
alivenkickin28
yeah mines louder too -- i had a busted hose not long ago and just replaed it with regular power steering fluid - the mopar kind will quieten it?
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #4 of 10 Old 05-06-2007, 12:44 PM
Upside
To flush the system did you just pull the hose off of the reservoir return and crank the motor? I've used that method in another vehicle but not the ZJ yet. I have some extra PS fluid in a sealed bottle on the shelf. Do Jeeps just take standard PS fluid or is it mineral oil like VWs/Audis?
Upside is offline
post #5 of 10 Old 05-06-2007, 01:36 PM
nashmd454
nashmd454's Avatar
I used a suctioning device to empty mine and added Lucas Power Steering and no more leaks( I used to have leaks too) and quiet.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #6 of 10 Old 05-08-2007, 07:23 AM Thread Starter
CTCSTrela
CTCSTrela's Avatar
Lol, I used a roll of paper towels. Just stuffed them into the res, soaked up the fluid, repeat until it's empty. Fill with mopar, run for a while, repeat.
02 WJ Laredo
4dr/4x4
Selec-Track
42RE
60K Miles
post #7 of 10 Old 05-08-2007, 07:29 AM
1BADDROP
Don't forget to turn the wheel back and forth to clear out the rack also.....
1998 ZJ SE I-6 w/ 42RE & 242, D30 & D35 axles 4"+ suspension , Moabs with 33" Bighorns, Borla Header, Magnaflow Muffler
1BADDROP is offline
post #8 of 10 Old 09-06-2015, 08:52 PM
alltimegirl
thats awesome news! you didn't have to replace to reservoir! i was just going ahead to, but i think ill save myself the hassle
alltimegirl is offline
post #9 of 10 Old 09-07-2015, 06:30 AM
PolkaPower
Unless the pump is bad you should not have to replace it. Don't use paper towel rolls to soak up the fluid in the res, that is idiotic. Just use a large turkey baster and suck out the old fluid. If you want 100% of the old fluid out then pull the feed hose and aim it into a bucket then start the Jeep while you pour fresh fluid into the res. All of the old fluid will get pumped out and when it runs clear with new fluid then shut it off, put hose back, and top it off.
You can also use the turkey baster to do this over several fluid changes.
Power steering and ATF are just about the same. Just different colors. They are both hydraulic fluids but ATF probably has more additives in it to help protect the transmission.
I'm using Mobil 1 synthetic ATF in my Audi's power steering right now. Noticeably smoother turning. Some people here on the forum use ATF in their power steering as well.
By the way, you probably won't get an answer to your question because this thread is 8 years old.
PolkaPower is online now
post #10 of 10 Old 09-07-2015, 07:39 AM
LouC
2007 WK
Eventually the pumps wear and need to be replaced; the Mopar reman pumps are good and only about $100 or so; you need a pulley puller to swap the pulley from the old one on your new one. You can use ATF4 in the which is a synthetic fluid...
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 05:50 AM
New power steering pump and pressure hose, now excessive pump noise Jeeples ZJ Grand Cherokee Forum 14 03-15-2011 03:59 PM
Noisy power steering pulley- 5.9 squashman702 ZJ Grand Cherokee Forum 5 08-22-2009 05:46 AM
How do you know if your power steering pump is speed portional steering? sweetie ZJ Grand Cherokee Forum 9 06-27-2009 10:04 PM
RIP power steering pump spichman510 ZJ Grand Cherokee Forum 8 02-09-2005 08:46 PM
