Noisy power steering pulley- 5.9 - JeepForum.com
post #1 of 6 Old 08-21-2009, 08:54 AM Thread Starter
squashman702
1994 ZJ
The 5.9 has a squeaking power steering pulley. Is this a sealed unit, and replacing it will fix the problem? Or will it require a whole pump?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #2 of 6 Old 08-21-2009, 10:06 AM
Virmagicus
Virmagicus's Avatar
The pulley should be pressed on and it will not fix the squeak.
Jeff
Virmagicus is offline
post #3 of 6 Old 08-21-2009, 10:49 AM Thread Starter
squashman702
1994 ZJ
Are you sure, there's a seperate part number for it on RockAuto.
Think Twice Garage
post #4 of 6 Old 08-21-2009, 10:57 AM
Virmagicus
Virmagicus's Avatar
A separate part number for the pulley? Well yeah ...
Jeff
post #5 of 6 Old 08-22-2009, 12:49 AM
Colorado 5.9
Colorado 5.9's Avatar
The bearings are in the pump. The pully is just a pully.
Oh! When you do take the pully off, inspect & check the bracket. It could very well be cracked & broken. If it is it's very hard to see. If you take it off the head you'll know for sure. Way easier to replace while you have the punmp off.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #6 of 6 Old 08-22-2009, 05:46 AM
newfieZJ
Sure it's not the belt ? I have one in my garage that made squeals , clicks and more . I thought it was a bearing too , the noise seemed to come fr the PS pump . No visual wear or damage done to the belt either , it was 1 yr old when it suddenly started one day . spray the belt with water , or even a few squirts of WD-40 , brg noises don't go away , belt noises will disappear for a few seconds , but always come back .
BTW , I bought a new pump at the time as well , it wasn't changed until I installed a new box many months after , it just wasn't needed . The old pump , still good , now in the new pumps box on the shelf .
worth a try . If you do end up with a pump issue , be sure to switch valves in the pump (check my recent posts for pics)
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
Noisy power steering pump? Possible quick fix. CTCSTrela ZJ Grand Cherokee Forum 9 09-07-2015 07:39 AM
Power Steering Pulley Problem bergz22 ZJ Grand Cherokee Forum 9 11-02-2009 10:33 AM
Power Steering Pulley Bracket DSPjeeper ZJ Grand Cherokee Forum 2 04-03-2006 09:40 AM
power steering pump pulley jeepzj9304 ZJ Grand Cherokee Forum 3 03-13-2006 12:18 AM
Need Power Steering Pulley HokieZ ZJ Grand Cherokee Forum 4 08-23-2005 07:11 AM
