noise while accelerating/decelerating around 60mph? - Page 2 - JeepForum.com
post #16 of 22 Old 10-12-2013, 08:44 PM
SDHarleydad
1994 ZJ
Just out of curiosity... could it be very high pitched almost a whistle? and....do you have an aftermarket air intake. They do tend to whistle as you feather the accelerator.
Casper
1994 JGC Laredo
SDHarleydad is offline
post #17 of 22 Old 10-13-2013, 06:39 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
The leaking seal might be an indicator of excessive heat in the pinion bearing area. I use an infrared thermometer to read mine occasionally.
http://www.jeepforum.com/forum/f9/an...temps-1107353/
Name:  bearing noise.jpg
Originally Posted by HighLonesome
coralman is offline
post #18 of 22 Old 10-13-2013, 11:04 PM Thread Starter
nodoze
Originally Posted by Dukcaln View Post
are front pinion bearings difficult to change?
also, no doze what happened after you changed the front and rear diff fluids, did it help?
I've had the gear oil sitting here for about 3 weeks but I honestly haven't had the time to change it yet. This weekend was free but I've been laying in bed all weekend with a nasty cold. I'm hoping to change fluid real soon and I'll definitely report back.
First Jeep, still a newb :)
1996 ZJ Laredo 4.0 w/ 242 SelecTrac
nodoze is offline
post #19 of 22 Old 10-16-2013, 10:24 AM
igids1
I had the same noise, except it was almost always on acceleration. It also caused a pretty bad vibration. To be honest, the noise started almost a year ago, and I just kept driving, until it got to be really bad.
I jacked up the rear wheels, and gave them a spin, the yoke was sliding in and out about 4 inches, and it is supposed to not move at all. When I took the yoke nut off, the yoke fell out, and the pinion gear fell out.
It took me about 1.5 hours to get the carrier and pinion out.
You will need a bearing puller/remover or a press to get the bearings out.
I am waiting for the new bearings/races to arrive to install
Mine is the rear pinion bearing. But the carrier bearings were pitted up pretty good as well.
igids1 is offline
post #20 of 22 Old 10-24-2013, 04:41 PM
Dukcaln
FYI. Changed my front diff oil and additive. noise went away about 90%. Have slight noise on acceleration only. More so at Freeway speeds above 55mph. Although the new frond diff oil really made it better I suspect the front bearing is going. Even know I have low original miles, what mileage usually sees these bearings start going out?
1979 CJ5 Hardtop - I6 W/Howell Fuel Injection 4-SPD, 33's, Winch, Racks & The Basics!
Dukcaln is offline
post #21 of 22 Old 10-24-2013, 06:44 PM
PolkaPower
My rear carrier bearings went at 126 or so. They were bad when I bought it. What additive are you using in the front?
PolkaPower is offline
post #22 of 22 Old 10-31-2013, 12:58 AM Thread Starter
nodoze
I changed my rear diff oil tonight and took it for a short drive. It seems quieter now The fluid in the rear was a light gray color so it was definitely time for a change.
I didn't get to change the front diff fluid, because I spilled some and didn't think I'd have enough fluid to complete the job. I'll have to pick up a little more fluid and get the front done next week.
After I get the front changed and have a few days to drive it I'll report back again on how the noise is doing.
nodoze is offline
