Noise when I turn - JeepForum.com
post #1 of 11 Old 07-19-2013, 10:23 AM Thread Starter
roc4117
Go Broncos!!!
roc4117's Avatar
Noise when I turn
I am hearing a noise coming from my driver's side front wheel when I turn right. It almost sounds like a metal rubbing on metal sound, not a banging or clunking. The faster I go the faster the noise is, when I go straight or turn left there is no sound. Any ideas?
It's a '98 Grand Cherokee Limited.
Rock
Freedom has a taste that the protected shall never know
Colorado Jeep Club Member #115
roc4117 is online now
post #2 of 11 Old 07-19-2013, 10:30 AM
PolkaPower
Check the rubber CV boot. If it's torn replace the axle shaft.
PolkaPower is offline
post #3 of 11 Old 07-19-2013, 11:45 AM
Midnightluckey
Could be a hub too, only whining when there is pressure on it. Jack up that side, grab the wheel top and bottom and give it hell. Any play and your hub is shot.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #4 of 11 Old 07-19-2013, 12:01 PM
zjosh93
I've had worn out brake pads do that too. Easy to check.
zjosh93 is offline
post #5 of 11 Old 09-28-2013, 04:32 PM
ewp418
Did you ever figure out the problem? My jeep just started the exact same thing
ewp418 is offline
post #6 of 11 Old 09-28-2013, 11:25 PM
coltman151
Yep mines doing the same right now. New brake pads and calipers. I'm gonna get a tube of grease and go crazy on the front end and some white lithium and keep going. Mine only does it on near full lock turns and sounds like I'm doing doughnuts lol.
95 Laredo 4.0, 2" RE BB, RC N2.0 Shocks, Custom Roof-Mount Light Bar w/ 6 lights, Bumpers deleted, Homemade sway bar discos, Michelin LTX 31x10.50s, and a Dog Box :)
Planned: Homemade Spare tire carrier, double shear front track bar, 4 adjustable rear control arms, New Rims and 33" Wrangler MT/Rs or BFG M/T KO's w/ LOTS of trimming.
coltman151 is offline
post #7 of 11 Old 09-28-2013, 11:43 PM
ewp418
Mine does whenever I am in a hard right turn. It almost sounds like it might be the shocks.
ewp418 is offline
post #8 of 11 Old 09-29-2013, 12:17 AM Thread Starter
roc4117
Go Broncos!!!
roc4117's Avatar
I replaced the shocks. Still makes the noise.
Rock
post #9 of 11 Old 09-29-2013, 01:21 PM
Oldfrog
2007 WK
I vote for brake pads. Mine did that.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #10 of 11 Old 09-29-2013, 04:03 PM
coltman151
maybe its another one of those undiagnosable noises. cause I went through a few deep mud holes yesterday, and it hasn't done it since.....
post #11 of 11 Old 09-29-2013, 06:20 PM
ewp418
It might just be a temperamental issue because it never happened before and I hadn't drove it for a week before it started.
ewp418 is offline
