noise help - JeepForum.com
post #1 of 30 Old 12-30-2012, 12:06 PM Thread Starter
mackcs212
1994 ZJ
noise help
Hey all, I have a problem that has been keeping my zj out of commision and I can not find the problem.
Problem being, when I shift into gear there is a short rattle, rattles when I drive (applying the gas) and when I put it back into park. All fluides are up, filters changed, to no avail. I will attach a video of me shifting into reverse then Back into drive.
Thanks for any tips in advance.
My Jeep Build Thread :
mackcs212 is offline
post #2 of 30 Old 12-30-2012, 12:12 PM Thread Starter
mackcs212
1994 ZJ
Jeep forum keeps crashing when I try to up load. Will try it from home in an hour.
Side note, when the jeep warms up the rattle stops
Rattle sounds in the area of the passenger side around the exhaust manifold maybe lower. Only one pers lol can't run throttle and dive down to listen fast enough.
post #3 of 30 Old 12-30-2012, 12:40 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Catalytic converter?
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 30 Old 12-30-2012, 12:44 PM Thread Starter
mackcs212
1994 ZJ
i dunno how to upload videos so i put it on youtube and attached a link to it.
http://www.youtube.com/watch?v=ad2F7...ature=youtu.be
post #5 of 30 Old 12-30-2012, 12:49 PM
Glued2aPost
Loose heat shield? Worn out Cat? Not the meow meow kind, emissions kind.
My ZJ has never been stuck, it was just taking a break from being so awesome!
Glued2aPost is offline
post #6 of 30 Old 12-30-2012, 12:56 PM Thread Starter
mackcs212
1994 ZJ
haha got ya. no to the heat sheilds, i couldnt find any around to replace the ones i had to cut off of the exhaust manifolds, so i put em on without any.
As far as Cat, never thought of it. i was worried it was tranny or tcase or an engine knock. But noise is too far forward for t case. I will have to take a look at the Cat. I had a bad O2 sensor and never had EGR Valve hooked up for a month or so, so maybe it plugged it up.
post #7 of 30 Old 12-30-2012, 01:27 PM
a70eliminator
It really don't sound like a catalytic converter rattle, that sounds like loose torque converter bolts, i would take off the inspection cover and look for rub marks, hopefully it's not an internal trans problem, it sound like somethings up with the flex plate/torque converter IMO.
a70eliminator is offline
post #8 of 30 Old 12-30-2012, 01:47 PM Thread Starter
mackcs212
1994 ZJ
Damn. Something I didn't want to hear. But ok. I will check it out and let you know
post #9 of 30 Old 12-30-2012, 01:48 PM
BLarkin
Really hard to tell from the video, but it almost sounds like a pulley. Is it more noticeable from the front or back of the engine?
BLarkin is offline
post #10 of 30 Old 12-30-2012, 02:02 PM Thread Starter
mackcs212
1994 ZJ
Back
post #11 of 30 Old 12-30-2012, 02:14 PM
BLarkin
Well, never mind lol. Better go with a70eliminator then, and try to take that inspection cover out of the way.
BLarkin is offline
post #12 of 30 Old 12-30-2012, 02:23 PM Thread Starter
mackcs212
1994 ZJ
Where abouts am I looking for the cover? Front, left, or right?
post #13 of 30 Old 12-30-2012, 02:28 PM Thread Starter
mackcs212
1994 ZJ
either of these two help isolate where abouts to look for the problem?
post #14 of 30 Old 12-30-2012, 03:16 PM
a70eliminator
It's just a sheet metal cover attached with two screws directly in the center lower of the engine plate between the motor and bell housing, you can reach it easily just laying under the jeep. Take it off and inspect the torque converter bolts by slowly rotating the crankshaft, I think there are 4 nuts that holt the torque converter acessed through that inspection cover.
post #15 of 30 Old 12-30-2012, 03:21 PM
BLarkin
I think those bolts are 15mm, maybe 16mm.
BLarkin is offline
5.2l , engine 5.2 , passenger side , rattles
