Noise in frontend on left side - JeepForum.com
post #1 of 5 Old 09-30-2003, 10:09 AM Thread Starter
mcioffi
I think I saw a posting about this but I cannot find it now. I'm getting a clunk when I turn left. It happens just about every time and I can actually feel the vibration through the floor boards. I thought it was something about the control rod, but I'm not sure. Does any have any idea what I'm talking about?
Thanks.
mcioffi is offline
post #2 of 5 Old 09-30-2003, 05:37 PM
RockPaws
RockPaws's Avatar
Check your track bar mount where it mounts to the frame, on the left side. Its just aft of the steering gear box. Check for wear in the joint or a loose attachment.
I have seen this before on a number of customers Jeeps cause simular noise or problem.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #3 of 5 Old 10-01-2003, 09:18 AM
lambar
I posted one a couple months ago. It turned out to the be left sway bar link was disconnected and rubbing up against the spring every time I turned.
1996 GC Limited 5.2L
2" Coil Spacer
30" General Grabbers
lambar is offline
post #4 of 5 Old 10-01-2003, 02:26 PM
jeepme79
When you are checking the track bar, it is best to have someone turn the wheel back and forth while you are looking at it.
2003 Dodge CTD Quad Cab 4x4, 320k miles and counting
Former Jeeps:
98 ZJ Limited, 5.2L, NP242, Jet Stage II (worthless), K&N, 245/75-16 BFG KO's
89 XJ, stock
79 CJ7 - Options included ripped soft top, leaky 4.2L (5qts/week), ripped seats, 33" tires, bondo & gray primer
jeepme79 is offline
post #5 of 5 Old 10-01-2003, 05:32 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Check the steering box bolts. They can and have loosened over time. They are right there in front of the sway bar links.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
Anyone moved zj spare to left side? Coblue ZJ Grand Cherokee Forum 10 12-19-2008 07:59 AM
Popping Noise From Left Front When Turning Left Only SSF556 WK Grand Cherokee & XK Commander Forum 1 08-14-2008 03:09 AM
help me diagnose this frontend noise... cleared4landing ZJ Grand Cherokee Forum 2 11-23-2007 08:30 AM
frontend noise and transmission question cobuekwe ZJ Grand Cherokee Forum 1 03-24-2006 10:26 AM
Heater Issue...Got the right side..no left 383Z28 ZJ Grand Cherokee Forum 3 10-29-2005 08:50 PM
