Quantcast Noise from front right wheel - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Noise from front right wheel
Old 07-22-2006, 12:08 AM   #1
shoeblade
Just want to start off by saying you guys have been really helpful
My front right wheel makes a eek eek eek noise when running, sometimes it gets louder when turning but more so when putting on the breaks.
Any ideas on what it could be?
Do I have a mouse stuck in there or what?
Thanks!
shoeblade is offline   Reply With Quote
Old 07-22-2006, 12:11 AM   #2
shoeblade
Changing a tire
whoops (deleted)
Old 07-22-2006, 12:47 AM   #3
DrumBoy
When is the last time you changed your pads? Could it be a tracker squeak from the pads that they need to be replaced? Dirt or gunk on the pads? Some kind of film on the rotors? Stuck caliper?
MySpace Profile
1998 ZJ 5.9 Limited
1998 ZJ 4.0 Laredo
1995 XJ 4.0 UpCountry
DrumBoy is offline   Reply With Quote
Old 07-22-2006, 01:15 AM   #4
shoeblade
The breaks looked fine.
One person said it was a wheel bearing, another said it was the universal joint.
Old 07-22-2006, 01:37 AM   #5
10achik
I ate what?
10achik's Avatar
I second the pads, either they need replacing or you need to clean out the brakes, they will squeek when they get dirty to, to much brake dust build up or something like that.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 33" Yokohama Mud Rovers
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Falken 912's (13.76 @ 103.85)
2006 Pontiac G6 GTP - (her's)
2001 Dodge Ram 1500 - CAI, Soft 8's, 31's
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline   Reply With Quote
Old 07-24-2006, 02:25 AM   #6
shoeblade
Not the breaks, must be some sort of joint or bearing. Don't know how to tell though.
Old 07-24-2006, 09:22 AM   #7
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
What year Grand do you have? That helps tremendously.
I'm assuming a '97, so there is a 99.99% chance that you do not have u-joints on your front axle shafts or pinion. You have CV joints, they tend to click and grind, not squeek. Probably the wheel bearings.
Jack that tire off the ground and see if there is any play when you try to shake or move the tire. (grab it at 9 o'clock and 3 o'clock)
HTH
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote
Glock Forum
