Noise from Distributer - JeepForum.com
post #1 of 3 Old 09-25-2003, 11:33 AM Thread Starter
gcl97
I have a ZJ 97 4WD with 123000 miles, I hear a rubbing sound coming out of the distributer, most noticebaly, in the morining start. Is this a CAP and ROTOR replacement job (replaced them almost a year ago), or the Distributor needs a replacement?
No ENGINE LIGHT yet.
Thank you in advance.
gcl97 is offline
post #2 of 3 Old 09-25-2003, 01:09 PM
RedArmy661
There are two possibilities. The inside of the distributor cap has worn out. Or the actual Shaft that spins the distributor has gone bad, and that's what it sounds like. The shaft that fires the distributor also turns the oil pump, so if this shaft is going bad then you could lose your oil pump eventually too. I recommend replacing the shaft, it'll be about $100 retail and you can replace it yourself with a haynes manual.
RedArmy661 is offline
post #3 of 3 Old 10-01-2003, 11:01 PM Thread Starter
gcl97
RedArmy661 thank you for your reply. Since my truck is still covered under the the extended warranty, I had the dealership diagnose and fix the problem. One thing I want to point out though, Chrysler do not sell dist. shaft by itself, they ONLY sell the entire distributer. Thanks again.
gcl97 is offline
Another day, another noise - whining noise while accelerating and slowing swataz ZJ Grand Cherokee Forum 8 12-11-2008 10:05 PM
Help! Front Diff Noise Or T-Case Noise ntaousakis ZJ Grand Cherokee Forum 6 04-22-2008 12:39 AM
noise 79cj5Dr ZJ Grand Cherokee Forum 4 11-23-2005 11:53 PM
distributer wiring 95 ZJ Blacktalonawd ZJ Grand Cherokee Forum 1 10-13-2005 04:40 PM
cherping noise/whining noise coming from passanger side LoweBudget ZJ Grand Cherokee Forum 0 12-06-2002 12:10 PM
