noise click sound under front - JeepForum.com
post #1 of 6 Old 07-02-2003, 10:57 AM Thread Starter
ely3rd
I am hearing a single pop/click sound when I apply gas from a stop. the noise occurs shortly after applying gas. it also does it when I stop. I don't believe it is the CV axles since it doesn't do it when I turn. Also I had the viscous coupler in the transfer case replaced about 100k miles ago, so I don't think that is it??
sounds like it is coming from the differential, but hard to tell.
I have '93 jeep grand cherokee laredo V8 4WD automatic tranny. differential is NOT limited slip.
any help appreciated
ely3rd is offline
post #2 of 6 Old 07-02-2003, 01:52 PM
Howler
Could be the CV front Driveshaft or the U-joints on the Double cardan. Get under the vehicle and grab the front driveshaft and shake it. You should hear the sound again if it is either of those. Howler
97ZJ 5.2L with 5" lift. 31" SuperSwampers TSL
To boldly go were no Grand has gone before.
Howler is offline
post #3 of 6 Old 07-02-2003, 03:26 PM Thread Starter
ely3rd
i recently replaced the u-joints on the front drive shaft and replaced the entire CV axle on the RHS. I guess it could be the CV axle on the LHS, but it is not clicking during turns.
ely3rd is offline
post #4 of 6 Old 07-03-2003, 06:18 AM
Howler
What about the CV on the Drive shaft (not axle)? Or the centering yoke on the Double carden joint?It just sounds like the problems I was having with my Driveshaft.
Howler is offline
post #5 of 6 Old 07-03-2003, 10:59 AM Thread Starter
ely3rd
my drive shaft doesn't have a CV and I have replace all the u-joints on the drive shaft including the double cardan.
I think it is the front left CV axle. I'll just let it go for a while. those CV axles can hold up for a while. longer than the stinkin garages tell you they will
ely3rd is offline
post #6 of 6 Old 07-03-2003, 11:07 AM
Howler
Did you replace your CV Shaft? Just stricks me as odd you would have the CV axle and not the shaft. Oh well. Now that I'm confused I'll just go hide in a corner. LOL
Howler is offline
Front end vib/click tommylee84 ZJ Grand Cherokee Forum 18 07-28-2009 02:53 PM
99 limited Qaudra trac2 front click drayset1010 ZJ Grand Cherokee Forum 0 01-11-2009 02:45 PM
Brake "Click" sound with new pads & rotors ILGlide05 ZJ Grand Cherokee Forum 2 12-30-2007 05:56 PM
WJ Click Noise Making Me Nuts!! McGR ZJ Grand Cherokee Forum 6 09-04-2005 09:31 PM
Click Click Clickity clack!!! 5point9Limited ZJ Grand Cherokee Forum 3 01-30-2004 03:25 PM
