nofire crank position sensor help http://www.jeepforum.com/ubb/brickwall.gif - JeepForum.com
post #1 of 4 Old 08-20-2009, 07:07 PM Thread Starter
pastorjakes
should both the supply wire and also the signal wire have 5vdc at all time then the ign switch on, engine off? should the signal wire while cranking remain at 5vdc? why is it not measuring 0vdc 0-5-0-5-0-5vdc while cranking? hum i rated the sensor bad do you?
can someone help me. i have a 1996 jeep gc 4.0 HO. i have no fire at the coil.pull the code p0320 i check the ckps. i check the volts to the sensor with fluke dvom and i had black led on middle wire (b) and red on the end (c)signal wire. ign switch on and had 5 vdc move the red to (a)5vdc supply (wt/bk color) and it also read 5 vdc with switch on. so then i crank the engine while volt meter red led placed on (c) signal wire (rd/lg color) and the black led on the middle ground wire (b) bk/lb color). the volt meter just measures 5 vdc and not 0-5-0vdc... so does this mean that the sensor is not send a signal to the pcm so the pcm can tell the coil to fire. i also check for high resistance and conudity on the wires harness at the sensor to the pcm all tests good. can some one please tell me what i miss. please help.. thanks in advance
pastorjakes is offline
post #2 of 4 Old 08-20-2009, 08:51 PM Thread Starter
pastorjakes
P0320
Trouble Code Conditions:
Engine cranking, vacuum signals present; and the PCM detected from 3-8 CMP Sensor signals without detecting a CKP Sensor signal.
Possible Causes:
CKP Sensor signal circuit is open or grounded
CKP Sensor VREF circuit is open or grounded
Tone wheel or flex plate damage or erratic CKP Sensor signals
CKP Sensor is damaged or has failed
PCM has failed
post #3 of 4 Old 08-20-2009, 08:51 PM Thread Starter
pastorjakes
can somebody please help me?
post #4 of 4 Old 09-26-2009, 05:36 AM
jeep795
maybe i'm a little bit late with a response, but it might be too quick of a change for your meter to pick up. Usually a job like that is for an oscilloscope.
jeep795 is offline
Crank Position Sensor dirt rider ZJ Grand Cherokee Forum 6 04-29-2012 06:12 PM
where is the crank position sensor? 5.2L jeepheller98 ZJ Grand Cherokee Forum 8 04-28-2009 07:48 PM
Crank Position Sensor? BliZZard911 ZJ Grand Cherokee Forum 8 01-12-2008 06:56 AM
Crank Position Sensor YJinMN ZJ Grand Cherokee Forum 18 07-02-2007 08:32 AM
Crank position sensor Othoni ZJ Grand Cherokee Forum 10 05-19-2007 10:14 PM
