nocked fron axle out of center? - JeepForum.com
post #1 of 6 Old 10-30-2009, 08:11 PM Thread Starter
FrankTheDank
was out romping in the snow last night and got a jolt and a bang and now the jeep feels like it tracks wrong. checked out the track bar and it looks good, axle appears like 1" to the passenger side... any ideas?
thanks
Frank
::4.0::42RE::242::Carolina Driveline::Spartan Locked D30::Aussie locked 44A::4.56!!!::4'' IRO LA::33/12'' Retreads::4"BS wheels::IRO T case skid::2 12'' Kenwood Subs 1000 Watt Kenwood Amp::Iceland Winch Bumper::Smittybilt XRC8::
STOCK 97 ZJ LAREDO-Daily Driver
I don't need to lie...that way I never have to remember what I said
FrankTheDank is offline
post #2 of 6 Old 10-30-2009, 08:33 PM
PlatinumNiner
Broken frame mount or track bar is the only thing that will do that.
PlatinumNiner is offline
post #3 of 6 Old 10-31-2009, 12:36 AM Thread Starter
FrankTheDank
checked track bar and mounts, all look good, its a newer IRO adj. track bar I installed with the lift..... ill get pics up soon
post #4 of 6 Old 10-31-2009, 12:44 AM
gatorayde
Check your measurements (lift height and the position of the axle), maybe your springs sagged a little since you last adjusted the TB.
gatorayde is offline
post #5 of 6 Old 10-31-2009, 06:22 AM
Area.3.Fiftyone
If it's 1" more to the passenger side and tracks differently, then something moved or broke.........
It's not rocket science.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #6 of 6 Old 10-31-2009, 10:21 AM
BigDaveZJ
Well you did something to knock it out of whack, and the trackbar is what locates the axle side to side. If it's an adjustable bar, just adjust it back to where it should be.
95 ZJ with lots of stuff
14 WK2
BigDaveZJ is offline
Jeep pulls to one side after alignment. Can the rear axle being off center do this? bjl95mustang ZJ Grand Cherokee Forum 5 10-06-2009 02:44 PM
axle off center stiller ZJ Grand Cherokee Forum 4 03-23-2009 04:54 PM
Replacing fron axle u-joint's cant get the caps out. bjl95mustang ZJ Grand Cherokee Forum 6 09-24-2008 07:57 PM
remove fron d/s on a 94 ZJ SFABlazer2 ZJ Grand Cherokee Forum 6 05-13-2008 02:48 PM
off center axle - adj track bar for 3"? QuadraTokn ZJ Grand Cherokee Forum 21 03-25-2007 05:01 PM
