Originally Posted by baxy
either maual is fine ATSG uses factory diagrams and specs
I use the SUPERIOR shift kits just get the regular shift correction package not the trans action
follow the instructions there is one JEEP specific step
upgrade to a 4 dics direct drum also the OD clutch can be upgraded by replacing the pressure plare thet is against the OD piston with 2 steels and an extra clutch plate (as assembled in the diesels)
replace all the thrust washers in the planets and inspect both sun gears for pitting buy a high eneryg front band (diesel)
one of these days I'm going to do a 46RE turotial but I'm usually too busy at work to take the time to snap all the necessary pics
I know this is your field and it makes alot more sense to you than myself
What are the chances of any hard parts that need to be replaced? I have found a few places online but i can't seem to find some of the parts that you mentioned. Is there a complete kit like the above or is it just pieced together? Should i be worried about the condition of the OD or converter? I just want to make sure i get all of the right parts as i am planning on rebuilding this tranny myself. How long should it take for a first timer? Thanks
