NO, start,started, now it's dying. While Ideling - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > NO, start,started, now it's dying. While Ideling
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAll Bilstein shocks & struts - Lowest Prices Ever and Ruffstuff Axle Simple Swap Kit!
Unread 06-08-2012, 10:01 PM   #61
hdrocknroll
Well I went out and ran some more errands and she was running flawlessly.
I thought it was running pretty smooth. Before this problem cropped up, but it is even running smoother Now.
It may be my imagination but it seems like I am maintaining the same speed with less pedal now.
Uni: When you were talking about taking off that bracket to install the coil, I was thinking I should take all that crap off and clean that stuff, but I didn't
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
[QUOTE=rooster51;13297693] Whats the worse that can happen? Your jeeps already broke.
[/QUOTE]
hdrocknroll is offline   Reply With Quote Quick reply to this message
Unread 06-09-2012, 06:39 AM   #62
Uniblurb
Uniblurb's Avatar
Good deal she's running flawlessly now, HD!
Yeah, I went the difficult route in removing the whole coil bracket but it needed it. It had never been off in 16 years and I had to put vise gripes on the wire connector blades/eyelets since seized, wrench on the bolt, with crap falling in my face.
Ticks me off to no end the dealer didn't check/clean the engine/PCM grounds when they installed the reman PCM 1 1/2 years ago. I'm sure that's what caused it to fail in the 1st place and why I had to install a 2nd one. Probably made my CKP fail twice too since it's grounded through the PCM. It's a vicious circle when it comes to these ground cables if they aren't clean/making good contact.
And if you ever have your alternator off again you may want to remove the mounting bracket and clean the where it connects to the engine block too. I couldn't believe how glazed/varnished it was since aluminum and steel/cast don't like each other.
All new/reman alternators now have a warning you better have a good ground wire attached. While maybe not necessary I made/ran a new ground wire from the right/bottom ground on the alternator to the front stud on the coil bracket just to be safe.
Also glad to see you washed it down and that dielectric grease should prevent some of the rust/corrosion in the future.
Uniblurb is offline   Reply With Quote Quick reply to this message
Unread 06-10-2012, 12:04 AM   #63
hdrocknroll
35 miles today, and no problems
[/QUOTE]
Unread 06-14-2012, 10:49 PM   #64
MrObvious
Problem solved now? If so I'm going to need to check this out on mine :/
Got it stuck. It's still stuck. It's so stuck I could call insurance and say it was stolen and no one would ever know. It's so stuck I don't know anyone with a capable enough 4x4 to even to to where I got stuck to winch or yank me out.
MrObvious is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 10:55 PM   #65
hdrocknroll
Yes still running great
[/QUOTE]
Unread 06-14-2012, 10:58 PM   #66
MrObvious
Looks like I will be going through and checking all my grounds again... I'm really trying to stay away from buying another PCM..
Unread 06-14-2012, 11:03 PM   #67
tklingbeil
Originally Posted by Hawkeye01
I had a problem very similar to yours and it turn out to be the battery. The battery was about 6 years old and when I replaced it with a new battery the problem went away.
I had same thing happen and it was battery also.. They gave me 3 bad batteries before one worked.. Have you checked the cables?
tklingbeil is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 11:14 PM   #68
ZeeJay1997
There should be a sticky on free stuff to do when your Jeep stalls. Mine had had at least 4 different stalls that were not related to the PCM or sensors that I fixed for about an hour labor. The next thing would be getting people to read the sticky.
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 11:23 PM   #69
hdrocknroll
That's a good idea, and if they weren't reading it, at least we could send them to it.
[/QUOTE]
Unread 06-15-2012, 12:58 AM   #70
phitmein
phitmein's Avatar
Please keep in mind here, that it is check and clean all your major connections and that doesn't mean just the grounds .
#1 Start with the battery .
There really aren't all that many and you can do them all in a hour or so and it cost you nothing unless you bust your knuckles .
Yes, it needs a Sticky and as I have said it here before many times .
" I have seen more Jeeps electrical problems fixed by cleaning the connections than by throwing new parts at it "
Not a perfect quote but close enough .
Phit
phitmein is offline   Reply With Quote Quick reply to this message
Unread 08-07-2012, 10:33 AM   #71
cherokeen77
I'm having a similar issue. Can someone list all the various grounds or sensors I need to be cleaning? I'll look up location in the Haynes manual.
cherokeen77 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2012, 10:37 AM   #72
jeepgal2k12
+1 vote for a sticky
1996 jeep grand cherokee laredo 2wd
240,xxx miles 4.0L i6
jeepgal2k12 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2012, 08:10 PM   #73
ZeeJay1997
I'm working on a post to cover all the free easy stuff. Will take a few nights to get it all covered.
Cherokee, the grounds are on side of the block and on the fender by the battery. Normally cleaning a sensor wont help. You can clean IAC for idle problems
Unread 08-07-2012, 09:10 PM   #74
tizzly
1994 ZJ
Id like it as a sticky also.
tizzly is offline   Reply With Quote Quick reply to this message
Unread 08-07-2012, 09:15 PM   #75
hdrocknroll
That's Great !!! Glad to see you are doing that, kudos to you, for putting in the time and effort to do it.
My ZJ ,has been starting and running fine since cleaning connections, and all my skin grew back from the wire wheel that jumped onto the back of my hand
[/QUOTE]
crank position sensor , stalling
