No start after heavy rain - JeepForum.com
post #1 of 8 Old 04-23-2011, 11:48 AM Thread Starter
gstroe
Hi guys, some electricals gremlins somewhere: car is parked outside and engine won't start after a heavy rain (the engine compartment is bone dry). This is the 3rd or 4th time it happens. It's been at least 3 hours now since the rain has stopped and still no start. It will most likley start a bit later in the afternoon. Last time it did this I sprayed the ignition wires and ditributor cap with WD40 but did not help. A colleague of mine mentioned a very similar experience he had with another Chrysler car and it was an electronic module in the engine compartment that was sensitive to excess humidity in the air and would not work. Any clues? patient is a 1996 Grand Cherokee Laredo (inline 6). Thank you very much,
George
gstroe is offline
post #2 of 8 Old 04-23-2011, 12:30 PM
Dodgeram1989
1976 FSJ Cherokee
Chryslers seem to be notorious for the Distributor cap being the issue after a heavy rain.
97 ZJ - Stock again
1976 Chief AMC 360 6 in lift, 35 inch tires
Dodgeram1989 is offline
post #3 of 8 Old 04-23-2011, 02:56 PM
rlcii77
?? Bad grounds, PCM connections, short elsewhere in electrical system,??
rlcii77 is offline
post #4 of 8 Old 04-23-2011, 04:39 PM
victorb
1994 ZJ
I have seen problems with not starting or stalling with just a little moisture with just a hairline crack in the distributer cap. I would look there first.
victorb is offline
post #5 of 8 Old 04-28-2011, 03:37 AM
mudpuppy_n_jeep
1980 CJ7
same ^^^.moisture in the cap.
80 cj7
boys 79 cj5
daughters 87 xj build
youngest girl 79 cj5
mudpuppy_n_jeep is offline
post #6 of 8 Old 04-28-2011, 07:41 AM
RuffDogg68
Yes check the cap..Also unhook the battery and then unplug your ECM and check for moisture in the plug-ins if you find some blow it out with some air and apply some dielectric grease on the plug-ins to keep out the moisture.
RuffDogg68 is offline
post #7 of 8 Old 04-28-2011, 08:09 AM
JS97ZJ
Put ty-wraps around your PCM connectors like in the picture below....
JS97ZJ is offline
post #8 of 8 Old 04-29-2011, 09:21 PM Thread Starter
gstroe
Thank you very much guys! I will obviously replace the distributor cap and hope this was the problem. Will know at the first heavy rain....
George
gstroe is offline
New guy here! pic heavy!! Ramoyer ZJ Grand Cherokee Forum 3 03-08-2011 11:23 PM
No start/hard start in/after heavy rain. BenzB ZJ Grand Cherokee Forum 1 03-08-2011 06:11 PM
Newbie - abs pump and heavy rain avocado ZJ Grand Cherokee Forum 0 10-30-2006 04:00 AM
No Start... Working all day in the rain...and other fun things jigawatt77 ZJ Grand Cherokee Forum 9 06-24-2006 06:31 PM
BB & 31s on. (poser) Pic heavy Wiley ZJ Grand Cherokee Forum 23 03-29-2006 08:41 PM
