No spark and no fuel - JeepForum.com
post #1 of 5 Old 08-17-2009, 01:22 AM Thread Starter
mcaleerwilliam
my zj died on my way home the other night without any warning. It will crank but it will not turn over. I immediately assumed it was the fuel pump because it was not priming when i turned the key. I replace the fuel pump and it is still not starting i checked to see if i was getting a spark and there is also no spark. I tested both the new and old fuel pumps by using a jumper cable from the battery to the connections and the fuel pump primes. I have no idea what it could be...
mcaleerwilliam is offline
post #2 of 5 Old 08-17-2009, 01:30 AM
SouthSeaPirate
Doesnt the alarm system disable all that? Just a thought... An issue with that would be my guess if you dont have any codes...
SouthSeaPirate is offline
post #3 of 5 Old 08-17-2009, 02:33 AM
FortCollinsZJ
ECU relay?
Check any of the relays under the hood, try some musical chairs, put an ABS relay in the fuel pump relay spot and try that.
FortCollinsZJ is offline
post #4 of 5 Old 08-17-2009, 04:59 AM
ZeeJay1997
Right idea, wrong year model. Musical relays is good troubleshooting but you'll be looking for the ABS relay for a long time on a 97. My first guess would be ASD relays. If no joy there try a CPS.
ZeeJay1997 is offline
post #5 of 5 Old 08-17-2009, 06:30 AM
newfieZJ
X2 check the ASD relay , swap it for another . If not . check all your fuses too .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
1993 GC 4.0 No Spark, No Fuel?? SD-Pimpin ZJ Grand Cherokee Forum 3 01-05-2010 11:47 PM
4.0 No spark and no fuel. Windowsrookie ZJ Grand Cherokee Forum 3 05-17-2009 10:05 PM
fuel or spark problem grip250 ZJ Grand Cherokee Forum 4 03-12-2009 10:04 PM
no spark or fuel liredneck ZJ Grand Cherokee Forum 2 01-09-2009 06:18 PM
NO GO!! I have fuel but no spark baymen4life ZJ Grand Cherokee Forum 1 11-24-2008 01:17 PM
