no sound coming from speakers - Page 3 - JeepForum.com
post #31 of 33 Old 03-21-2013, 09:03 PM
xrunndonex
1994 ZJ
Originally Posted by vforce1 View Post
fuse is good. im stumped..
Hammers fix stuff there won't be no problems after you use the hammer
xrunndonex is offline
post #32 of 33 Old 03-22-2013, 07:27 AM
exador
1970 CJ5
Are you using the factory wiring when its giving you problems?
If so try hooking up both speakers directly to head unit with some extra speaker wire. If that works you have a problem with your factory wiring and i would recommend running new wires to all 4 doors. It may cost more and be a little time consuming but it will only make your sound quality better anyways.
Your headunit has plenty of juice to power the speakers, if it doesn't work the HU (or speakers??) may need replaced.
exador is offline
post #33 of 33 Old 03-23-2013, 12:34 PM Thread Starter
vforce1
ok i tried your suggestion and it worked, i wired the speaker directly to the head unit did some wire management (real crap job...) and closed it all up. looks like crap but at least it works thanks.. if only i knew how to route the wire into the door
vforce1 is offline
