no sound coming from speakers - JeepForum.com
post #1 of 33 Old 03-19-2013, 12:05 PM Thread Starter
vforce1
i bought this orvis only a few days ago and i just now see theres no sound in it...( i removed what looked like a bypass when i saw the amp removed guess i shouldnt have cus 1 speaker was working before i did but i cant remember the wires that were bypassed)
i find it theres no stock amp in the car is there a way to bypass it? this orvis comes with a aftermarket pioneer head unit and only 2 sony xploits exist in the car , i just bought 2 10" kicker subs with kicker box and db audio 1000w amp with that boss wiring kit will install that too but how do i bypass the stock amp for the speakers?
vforce1 is offline
post #2 of 33 Old 03-19-2013, 12:36 PM
exador
1970 CJ5
Was the bypass you removed under the driver side rear seat?
original post from SJZhttp://www.jeepforum.com/forum/f13/z...bypass-254357/
Edit: you just connect the speakers "+ and -" to the matching "+ and - imput"
for example
#1) left rear speaker + (white w/red stripe)
needs connected to
#5) left rear + imput (brown w/yellow stripe)
exador is offline
post #3 of 33 Old 03-19-2013, 01:03 PM
exador
1970 CJ5
Also that chart will let you reuse some of the stock wiring for your new amp so you don't have to run as many wires back.
2 constant 12volts and 1 remote(if you use this you may have to check the wiring to head unit to make sure it is hooked up right.)
exador is offline
post #4 of 33 Old 03-19-2013, 01:05 PM Thread Starter
vforce1
thanks for the info, really great forum here xD
and yes it was under the seat that i removed the bypass
vforce1 is offline
post #5 of 33 Old 03-19-2013, 01:15 PM
exador
1970 CJ5
no prob, just went through this myself last month and used this chart.
Congrats on the Orvis!
exador is offline
post #6 of 33 Old 03-19-2013, 04:42 PM Thread Starter
vforce1
ok weird thing happends, i only have 2 speakers LF and RF, i hook up the front drivers speaker and it works fine. but when i hook up the left speaker it both dont work..
vforce1 is offline
post #7 of 33 Old 03-19-2013, 07:50 PM
thetammon
I bypassed the stock amp, just connect the corresponding wires like what's said above. So my speakers are running off the deck, and subs on an new amp
thetammon is offline
post #8 of 33 Old 03-20-2013, 12:23 PM
exador
1970 CJ5
That's odd, maybe in the process you knocked the other one loose?
I had to redo a couple of mine in the end.
If i remember correctly the chart was wrong. A couple of the blue were really light blue but the stripes were the right color.
exador is offline
post #9 of 33 Old 03-20-2013, 12:42 PM
Scopez
1994 ZJ
I run my door speakers off a 240w pioneer amp. My factory amp is still hooked up also. I'll be bypassing it soon though, if it isn't already bypassed. I run two 12" pioneers off a 1000watt Kenwood monoblock class d amp.
All my door speakers are pioneer, along with my headunit. I have 2 JVC 6.5s in the rear hatch, they are tapped into the rear door speakers.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #10 of 33 Old 03-20-2013, 12:55 PM
exador
1970 CJ5
That is a pretty sweet idea I might have to do that.
exador is offline
post #11 of 33 Old 03-20-2013, 01:58 PM
Scopez
1994 ZJ
I'll post some pictures when I go back up to the shop and work on the ZJ.
Scopez is offline
post #12 of 33 Old 03-20-2013, 04:39 PM
Scopez
1994 ZJ
Posting said pictures...
Scopez is offline
post #13 of 33 Old 03-21-2013, 12:25 AM Thread Starter
vforce1
wow that aint bad, im gonna do something like that when i get a chance , 1st thing is the front end that needs fixing, i made another post about it but nut much help given there
vforce1 is offline
post #14 of 33 Old 03-21-2013, 04:15 AM
xrunndonex
1994 ZJ
Wish I could do that. Looks badass so much sound deadener in my hatch though :/
xrunndonex is offline
post #15 of 33 Old 03-21-2013, 12:38 PM
exador
1970 CJ5
Attachment 589802
Thats sweet.
Can you tell the difference from driver seat?
I imagine it makes a big difference for anyone riding in back but I usually don't have many passengers at once.
exador is offline
