No Sound..... - JeepForum.com
post #1 of 9 Old 04-24-2002, 07:37 PM Thread Starter
Landon
No Sound.....
I have a 95 Grand Cherokee with the Infinity stereo system. I got in it the other day, started it up, turned on the radio.... but no sound. The radio operates normally, other than there is no sound, the antenna doesn't come up, and the lights on the equalizer don't light up. I have checked every fuse in the power distribution center under the hood, and also in the fuse box. I even cleaned off the connectors on every fuse with sand paper, to ensure a good connection, but all to now avail. A few days after it stopped working, it spontaneously started working again, perfectly... for about a week. Then, same thing happened again, and that's been almost a week ago. I would greatly appreciate any advice on the matter, because at this point I am completely out of ideas.
Landon is offline
post #2 of 9 Old 04-30-2002, 03:59 PM
FlynLow
Hey. Did you check the fuse in the headunit? There is a fuse inside the radio. If that does not work out then bring it to a local audio dealer. Hope that helps.
Holler.
Holler
"If It Ant Broke Ur not Tryin Hard Enough."
FlynLow is offline
post #3 of 9 Old 11-15-2002, 01:43 PM
guelch
I've got the exact same problem with my stereo. I remove the head unit, opened it up and looked for a fuse but counldn't find one. Does anyone know what the fuse looks like or where it is located?
guelch is offline
post #4 of 9 Old 11-15-2002, 05:22 PM
ALS59LTD
ALS59LTD's Avatar
I'm not sure if the factory deck would have a fuse built in, check for loose connections on the back of the radio. Grab yourself a wiring diagram and a testlight or Multimeter and see if you can find any dead wires. It really does sound like a fuse though. maybe check the connections going to the radio from the fusebox.
-Alex
http://www.jeepforum.com/forum/f22/turbocharged-2-4l-jeep-tj-me-too-2255329/
ALS59LTD is offline
post #5 of 9 Old 11-17-2002, 05:05 PM
Kess
i have the same thing go on, but the wierdest thing, its only when someone opens/closes the rear passenger door, and if its ever not working i open and close that door and viola!, i dont know what the hell is going on but try that....
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline
post #6 of 9 Old 11-17-2002, 05:11 PM
Bob J
Bob J's Avatar
1984
Sounds like the switched power lead leaving the radio isn't turning on the accessories... If fuses are ok only thing left would be a bad head unit or a faulty wire...
Kess sounds like it could be a loose wire either going through the door to the speaker, or under the carpet by the door.. do you have the exact same problem with no power antenna or just no sound?
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #7 of 9 Old 11-17-2002, 06:36 PM
Kess
just the no sound, i have a stationary attenna
Kess is offline
post #8 of 9 Old 11-17-2002, 06:59 PM
Bob J
Bob J's Avatar
1984
might be a loose speaker wire in the door.
I had a similiar problem that the radio would go quiet over big bumpers and come back after the next.. what happens is the radio amp detects a short and instead of running the risk of burning out it just turns off..
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #9 of 9 Old 11-18-2002, 06:43 AM
ALS59LTD
ALS59LTD's Avatar
If that is the case, if you have the infinity setup, the amp is turned on by the switched lead also. if the amp is not being turned on, you will get no sound, check for power and signal going to the amp.
-Alex
ALS59LTD is offline
Does this sound right? Pomorza ZJ Grand Cherokee Forum 11 05-09-2009 01:01 PM
No sound BanjoBear ZJ Grand Cherokee Forum 7 11-07-2007 02:54 PM
Bad Sound Mr Q X ZJ Grand Cherokee Forum 9 05-04-2007 07:06 PM
has anyone sound deadened their WJ doors to improve sound? mat1 ZJ Grand Cherokee Forum 1 12-19-2006 05:00 AM
This sound about right? Stephan ZJ Grand Cherokee Forum 0 10-07-2005 10:21 AM
