No Reverse - Tranny Fluid Was Low... 1998 Grand Cherokee - JeepForum.com
post #1 of 6 Old 09-04-2006, 10:11 AM Thread Starter
Ramblin Randy
Howdy neighbors... first time here... love my Jeep.
Anyway my 98 Grand 6cyl automatic ran a little low on tranny fluid. It works fine in all forward gears. It just suddenly stopped going backwards when in reverse. Being two quarts low I'm sure will haunt me... need to keep an eye on that small fluid leak.
More info... when placed into reverse I can hear the drive shaft to the rear wheels ingage, there is a slight bit of movement and then nothinging happens. I filled it up with tranny fluid, left it sit for over a day, and the jeep moved a wee bit better in reverse for a few seconds. Attemping this again immediately I was back to where I started with but a hint of movement.
Is this a filter issue ? Since purchase of this well maintained Jeep I have not done a tranny tune up and plan on fluid change this week if that is recommmended. Jeep just turned 200,000 miles, mostly highway, zero offroad.
Thanks in advance,
Ramblin Randy
Ramblin Randy is offline
post #2 of 6 Old 09-04-2006, 10:17 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
Randy, what are you doing when you check the fluid level?
In these GC's you've got to get the tranny good and warm (drive about 15 miles) and check it with the engine running and the transmission in neutral.
If you are going to do a service on the tranny filter, make sure you grab a Haynes and adjust the transmission bands while you are in there. There's one adjustment inside the pan and the other is outside and a pain to get to.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #3 of 6 Old 09-04-2006, 10:25 AM Thread Starter
Ramblin Randy
Thanks for the quick response...
I'm an entreprenure and sometimes the "worry" factor blocks out real brain waves and we do stupid things like forgetting to check the fluid while in neutral. That's all water over the damn.
Will a new filter and new fluid fix things ? My pal is a GM Mechanic and should be albelto help me with the adjustment process.
What about getting all the old tranny fluid (nice and red) out of the torque converter and nooks and crannies.... better to get a professional to do this. I will note that I followed the manual and used decron/mercron, and I want to do the right thing and get some ATF4 in there as most folks suggest.
Ramblin Randy
1998 Jeep
1965 AMC Rambler Wagon
1966 Ford C700 Car Hauler
post #4 of 6 Old 09-04-2006, 10:29 AM
Woody
Woody's Avatar
1985
Don't worry about doing a flush, and at your mileage it wouldn't be wise to flush it.
Just drop the pan and get out the six quarts or so that will come out that way, adjust the bands, replace the filter, install the pan, refill with ATF +4. Don't use anything else in it.
Woody
Woody is offline
post #5 of 6 Old 09-06-2006, 09:29 AM Thread Starter
Ramblin Randy
Ok I've got a online manual (from my local library) that has good adjustment instructions. Do I need any special tools other than a torque wrench ?
Thanks again Woody for the quick response.
Ramblin Randy
post #6 of 6 Old 09-06-2006, 12:16 PM
Woody
Woody's Avatar
1985
Torx bit T-20 I believe for the filter, and made sure you've got the proper socket for the band adjustment that is outside the pan. It's kidof a werid one, I believe I used a 15/64's on it.
Woody
Woody is offline
1998 grand Cherokee 5.9 vs 1999 Cherokee 4.7 rrich49132 ZJ Grand Cherokee Forum 89 11-27-2010 06:11 PM
1998 Grand Cherokee tranny issue, 2nd to 3rd gear Mackee ZJ Grand Cherokee Forum 5 07-16-2009 07:03 PM
ABS light on 1998 Grand Cherokee grapeman ZJ Grand Cherokee Forum 2 06-02-2009 01:33 PM
Help for a 1998 Grand Cherokee TSI lori2stj ZJ Grand Cherokee Forum 11 01-04-2009 11:06 PM
1998 Grand Cherokee Laredo 4x4 Tranny problem mackack ZJ Grand Cherokee Forum 1 04-19-2006 05:16 PM
