no reverse or neutral or park - JeepForum.com
post #1 of 9 Old 05-04-2013, 09:03 PM Thread Starter
skiwee75
2004 KJ Liberty
98 jeep Cherokee 2 wd kid got it stuck now it has no reverse but no park or neutral either when it is in reverse park or neutral the motor is under a load but jeep wont move it has drive and goes through all forward gears perfectly shifting linkage looks good any other advice before I pull it?
skiwee75 is offline
post #2 of 9 Old 05-05-2013, 09:18 AM
Oldfrog
2007 WK
Did the linkage slip? Look closely at it.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 9 Old 05-05-2013, 09:52 AM
um7267
maybe when he got stuck it pulled the nns(neutral safety switch) plug out? if not maybe check under the console something may be loose
nns- does it start in gear?
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #4 of 9 Old 05-05-2013, 10:10 AM Thread Starter
skiwee75
2004 KJ Liberty
I really don't have park so I quess it is starting in drive cause that is all it has all other gears seem to be under a load
skiwee75 is offline
post #5 of 9 Old 05-05-2013, 11:16 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
pull the shift linkage off at the trans and see if you can put it in park. then put the shifter in park and see if the linkage lines back up.
there's a lot of damage you can do to these transmissions if you rock it back and forth when stuck in a mudhole.
is it a cherokee or a GRAND cherokee...there's a big difference.
ratmonkey is offline
post #6 of 9 Old 05-05-2013, 01:26 PM Thread Starter
skiwee75
2004 KJ Liberty
grand Cherokee Laredo 2wd
skiwee75 is offline
post #7 of 9 Old 05-10-2013, 06:19 PM Thread Starter
skiwee75
2004 KJ Liberty
update pulled tranny had clutches actually melted together and valve body with broken springs darn kids
skiwee75 is offline
post #8 of 9 Old 05-10-2013, 07:44 PM
DickDickle
I've done that rocked my jeep back and forth in the mud to the point that reverse was a forward gear
DickDickle is offline
post #9 of 9 Old 05-10-2013, 10:02 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
usually it's just the direct drive clutch they break when rocking back and forth in a mud pit. that must have taken some seriously stuipid effort.
