no power steering assist - JeepForum.com
post #1 of 7 Old 08-18-2013, 04:56 PM Thread Starter
dhirocz
Hi all. Been lurking for a long time. Decided it's time to post.
My '96 ZJ decided it was tired of giving me power steering assist. Last week after parking I heard a pop and found the power steering pump shaft pushed about 1" out of the pump...ate the belt up somewhat but the pump wasn't noisy and I managed to drive it home without power assist. That was fun.
So fast forward to this weekend, I put in a reman pump(I know), with the EVO installed on it. I took the time to bleed it, front end unloaded, engine off, then running. Got all the air out. No dice. I still have NO assist. None at all. I did verify the pump is making pressure and is working.
Considering the pump is working but I still have no assist at all, I'm assuming there might be a problem with the steering box/spool valve. Anybody have a quick doagnosis on this one before I spend the cash? I'm going to be letting her go soon and looking into upgrading into a 5.9, so I'm looking at getting it back up and going before letting it go. If it matters, it has 258k miles on it on the stock steering box.
dhirocz is offline
post #2 of 7 Old 08-18-2013, 07:51 PM
Smokey1r
Try checking the high pressure hose, bet its kinked or internally collapsed and the back pressure is what damaged the original pump to begin with.
Smokey1r is offline
post #3 of 7 Old 01-11-2014, 10:31 PM Thread Starter
dhirocz
Just figured I would throw this out here. Turns out my box had the spool valve blow a seal.
I also have some F body stuff lying around the house. Actually, I just finished parting one not too long ago, as I am in the process of restoring one at the moment that's down for paint, and stumbled on to this by accident when I set them down next to each other. The cases are dimensionally identical.
Turns out the third generation Fbody box is an upgrade to the Jeep. Used the Jeep's pitman arm and away I went. Funny, my Camaro has a Jeep steering shaft in it which should have been a sign. These Saginaw boxes have been used as far back as the early 60's. It reduced my steering down to 2 1/2 lock to lock from 3 1/2 and restored my power steering. Direct bolt in. It's quiet and works and I'm happy
This also means that S10 manual boxes and aftermarket Saginaw trick boxes for those applications should also fit. Enjoy.
dhirocz is offline
post #4 of 7 Old 01-11-2014, 10:51 PM
Smokey1r
Glad ya fixed your issue!!!!!.
Its rare to have an o-ring break on the spool valve as it only has the motion the torsion bar allows from the stub shaft in the valve body.
2 1/2 turns is 12:7:1 ratio, what the jeep came from the factory with so ya basically restored the original function of the jeep by putting that old box in!!!.
Them Saginaw power steering gears have been used for decades in a multitude of cars and trucks of many brands!, most interchangeable!!!
Smokey1r is offline
post #5 of 7 Old 01-12-2014, 10:51 AM
durango-bob
2006 WK
The popular upgrade is to install a box out of a '99 Durango. The piston is 1/2" larger providing more turning power.
durango-bob is offline
post #6 of 7 Old 01-12-2014, 05:30 PM Thread Starter
dhirocz
I'm just glad to know how interchangeable they are. Odd, the box that came out was a 14:1 box. This is a 12.7:1 box that I put in. Maybe it was changed in the past? Might be that '96 only thing with the EVO power steering pump, which I am going to look into deleting next.
I'm also rather surprised that POS steering box bracket wasn't in like 10 pieces.
dhirocz is offline
post #7 of 7 Old 01-12-2014, 05:35 PM
Smokey1r
Ya it obviously was changed out for a 14:1 ratio box at some point in its life.........
Smokey1r is offline
