No power steering - JeepForum.com
post #1 of 12 Old 08-20-2013, 04:28 AM Thread Starter
jblinga
No power steering
97 Grand Cherokee 5.2 Laredo
Hi all, new to the forum. I have done some searching but I can't seem to diagnose/fix this issue.
Turn of events:
Replaced steering box to eliminate play and rule out a possible contributor to death wobble. Flushed system.
Upon initial restart, power steering worked for 5 minutes then stopped working. Bled the system by having front axle off the ground, engine off and turn just short of lock to lock for 40+ times.
No change, power steering completely gone.
Made sure high pressure line and return line are clear and free of obstructions. Also checked the flow from the pump and from the steering box. Bled system.
No change
Warrantied remanufactured O'Reilly steering box, bled system another 40+ times.
No change
Replaced power steering pump w/O'Reilly reman, bled system.
No change
What else am I missing?
Any and all help/advice is appreciated.
I want this thing out of my garage!!!
Haha
TIA
jblinga is offline
post #2 of 12 Old 08-20-2013, 05:06 AM
ZeeJay1997
try putting it on the ground and go stop to stop 20 times, holding it at the stops for a few seconds
ZeeJay1997 is offline
post #3 of 12 Old 08-20-2013, 05:26 AM
shaban
After initially filling the system, have you checked the level? It should've dropped and a lot of bubbles will appear in the steering pump reservoir.
Wait until the bubbles disappear (10 mins), start it for 1 minute, turn your steering stop-to-stop, check for bubbles and top up the fluid. Again, wait for some time, if there are any bubbles until they all go away.
I had to do that about 3 times.
shaban is offline
post #4 of 12 Old 08-20-2013, 05:28 AM Thread Starter
jblinga
Fluid level has always been close to full during all the things I've tried thus far.
Again, the power steering has been completely gone after the initial restart. No progress has been made after all the trouble shooting/bleeding.
jblinga is offline
post #5 of 12 Old 08-20-2013, 06:29 PM Thread Starter
jblinga
Bumpage
Please help
jblinga is offline
post #6 of 12 Old 08-20-2013, 08:52 PM
Smokey1r
You have your clue right there with the fluid level constantly being close to full in the reservoir.
Replace your high pressure line!!!.
Its most likely internally collapsing under pressure, if you have fluid flow you will lower the level of the reservoir as the air pockets in the system get pushed to the top as you turn the steering lock to lock.
Since your saying the reservoir is always close the top your not getting any or very little fluid flow.
Smokey1r is offline
post #7 of 12 Old 08-20-2013, 11:24 PM Thread Starter
jblinga
Fluid has always been close to the full when hot mark, not close to the top of the reservoir. Fluid rises and falls substantially when bleeding. Air bubbles visible when bled
jblinga is offline
post #8 of 12 Old 08-21-2013, 01:06 AM
shaban
Just had a thought, could have something to do with that solenoid on the pump? The speed-proportional steering one. Have you got it connected? Maybe try disconnecting it.
shaban is offline
post #9 of 12 Old 08-21-2013, 01:09 AM Thread Starter
jblinga
Doesn't have speed proportional pump
jblinga is offline
post #10 of 12 Old 08-21-2013, 12:12 PM
Smokey1r
Just a thought i had, listen to the power steering pump, when you start up do you hear it laboring like when you would turn and hold the steering all the way to lock even though its in the center or anywhere in between but not at wheel lock?.
Another thought, pull the high pressure line off of the steering gear and check the one way valve on the steering gear, just poke it with a screwdriver and see if it has spring tension and returns to a closed position, also check that your O-ring isn't off the fitting on the hose and blocking the fluid flow.
Smokey1r is offline
post #11 of 12 Old 08-23-2013, 01:59 AM Thread Starter
jblinga
Update:
I had o'reilly warranty me another power steering pump, bled system for over an hour. Air bubbles the whole time.
Fired it up and voila! Power steering is finally back.
I am still bleeding air out now.
jblinga is offline
post #12 of 12 Old 08-23-2013, 07:34 PM
Smokey1r
Excellent!!!! glad you got it fixed!!! lets hope this pump last you the life of the jeep!!!!
Smokey1r is offline
