NO power to radiator fan. help - JeepForum.com
post #1 of 4 Old 09-15-2009, 05:09 PM Thread Starter
gharris54
There is no power getting to my radiator fan, the fuse is good. I know the fan works because I ran a wire from the battery to the fan and it turned on but when I put the multimeter on the power connection going into the fan motor I get nothing so why is there no power going to it??
In the hanes manuel it also mentions a relay but I could not find one that pertained to that fan, is there one and if so where is it?
If there is not a relay what might the problem be. The hanes manuel says if the fan is not getting power and the fuse is good then you have to take it to the dealer because it is a computer problem, is that true? I sure hope not because my wallet hates the stealership.
2000 dubya jay, IRO 3'' and 265/75R16 bighorns, quicker discos, custon spring retainers, custom ford 9'' rear end with the stock wj discs
Dana35 SOLID diff cover and a lock-right locker for a Dana35 for sale
gharris54 is offline
post #2 of 4 Old 09-15-2009, 05:16 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Its probably the relay. Its located underneath the passenger side head light.
You may have an open recall for the relay. Check it out on Jeep.com
If not, I have some good used ones for sale.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #3 of 4 Old 09-15-2009, 05:28 PM Thread Starter
gharris54
Im guessing I have to take off the headlight to get to the relay right?
post #4 of 4 Old 09-15-2009, 08:13 PM Thread Starter
gharris54
No worries, I fixed it. You had to take off the headlight and cut a hole in the plastic under it to get to the relay. The hanes manual did not mention that lol. It just said check the relay hahaha.
2004 Lerado - Driver Power Lock & Power Windows lbi2000 ZJ Grand Cherokee Forum 3 10-20-2008 04:58 AM
radiator fan not working after replacing radiator Airborne Lee ZJ Grand Cherokee Forum 5 07-23-2006 06:53 PM
WJ Power Steering Fluid Radiator Enhancement nedsud ZJ Grand Cherokee Forum 33 06-28-2006 11:55 PM
Dead radio, interior lights, power mirrors and power locks. Lisa ZJ Grand Cherokee Forum 5 09-04-2005 10:34 PM
radiator fan power module. bud84ro ZJ Grand Cherokee Forum 2 10-26-2004 07:47 PM
