No power to after market head unit--New Jeep (My 1st) - Page 2 - JeepForum.com
post #16 of 20 Old 12-25-2013, 07:54 PM Thread Starter
dorrmann27
UPdate-
Changed Blue-to-blue connection to current --Blue/white-to-Blue
Powers up sometimes* when the pink-to-pink connection touches yellow-yellow.
This only happens sometimes seems as if the unit has to reset after a period of time and will again regain power but does not consistently stay powered on.
Same results as Blue to Blue conn. and seems no matter what pattern the pink and yellow are in it will gain power periodically but not regain power after disconnect.
dorrmann27 is offline
post #17 of 20 Old 12-25-2013, 08:01 PM Thread Starter
dorrmann27
Originally Posted by Pierre_r View Post
When i put in a new sony xplod headunit in mine.
There was 4 wires that had to be conected in a special way to make it work.
The wires are red and yellow from the headunit and from the existing wiring
The first option is for Switched power supply, then the red wire goes to the other red and the yellow goes to yellow.
The second option is for Continuous power supply, then the red wire goes to yellow and the yellow goes to the red.
The third option is for cars without ACC position, then both the red and yellow from the headunit goes to the yellow that comes from the car.
Only thing is i dont remember wich one worked on my ZJ but one did nothing and one of them freaked out the ac panel.
Attempted all 3 options, I have an accessory switch, but only works when connecting both yellow to both red and still then, not always will it work :/
post #18 of 20 Old 12-25-2013, 08:13 PM
Pugulis
There may be a problem with the "plug and play" jumper. Maybe the wires aren't quite right. This is what you should have coming out of the unit itself. Red, ignition. Yellow, battery. Black, ground. Solid blue is only for power antenna. Blue white is power for the amp. Ignore the colors on the jumper. Connect the Red/white stripe wire from the dash to the solid red wire from the HU. Connect the pink wire from the dash to the yellow wire from the HU. Disconnect all other wires. Then one by one connect the speakers.
[_][]☺[][][]☺[][_] RIP to my 96' Grand Cherokee Laredo 344,700 miles and welcome to my new 2001 WJ
Pugulis is offline
post #19 of 20 Old 12-25-2013, 08:23 PM Thread Starter
dorrmann27
Ran out of day light and energy. Ill be back after the sun rises with an update on complete rewiring hopefully this works
1993 Jeep Grand Cherokee Limited 4.0L--Dayton Timberline A/T 31"
post #20 of 20 Old 12-26-2013, 12:39 PM Thread Starter
dorrmann27
Update- Multiple Blown fuses (Radio Fuse #10 blue 15 amp; power lock/memory fuse #8 blue 15 amp)
Power wiring- From bare car wiring to after market Head unit
Pink/Grey stripe(car)-Red Wire(radio)
Pink/White stripe(car)-Yellow Wire(radio)
IMG_20131226_121003_462 (3).jpg   IMG_20131226_140120_793 (2).jpg   IMG_20131226_140157_452 (2).jpg
amp , bypass , power , radio , wiring
