no parking lights, rear wiper, dash lights flash with blinker - JeepForum.com
post #1 of 7 Old 05-21-2006, 02:22 PM Thread Starter
kemicalburns
1998 5.9 limited
I just recently towed a small trailer and since have lost my parking lights and dash lights. when the head light switch is in the auto position and i turn on my blinker or hit the breaks the clock, Odometer flash. I have checked the fuses under the hood and all look good. any help guys, thanks
98 limited
5.9ltr
stock
2.5" exhaust flowmaster
kemicalburns is offline
post #2 of 7 Old 05-21-2006, 03:25 PM
Meerkat
Does your Jeep have the factory installed tow package, or did you install an aftermarket one?
If you installed an aftermarket one, how did you connect the lights for the trailer?
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 7 Old 05-21-2006, 03:29 PM Thread Starter
kemicalburns
its got the factory tow package. I had to use a reducer and figured the trailer might have shorted something out. the problem is none of the fuses are bad. an not sure how these items can all be connected. the heads lights work and the break lights still work along with the blinkers so i would think the bulbs are still good all the way around. Also the fog lights wont turn on , the switch does not light up
98 limited
5.9ltr
stock
post #4 of 7 Old 05-22-2006, 10:38 AM Thread Starter
kemicalburns
Anybody else
98 limited
5.9ltr
stock
post #5 of 7 Old 05-22-2006, 04:36 PM
Meerkat
I'm not sure what you mean by 'reducer'. I'm thinking you mean an adapter to convert the round receptacle to a flat 4 pin plug. Which shouldn't cause any problem.
There are fuses behind the passenger side kick panel as well. Have you checked all those? Also the relays. The only thing that I can think of at this point that would be in common with the elements that are malfunctioning is the Body Control Module. The BCM controls your fogs and the headlight functions when in Auto. However, if a relay feeding the BCM has gone bad, you could experience similar symptoms.
HTH
Warren
Meerkat is offline
post #6 of 7 Old 11-25-2009, 11:29 PM
JohnnyCommando8
1994 ZJ
I don't know if anybody is still reading this thread but I just got done with this issue on my wife's 1998 ZJ 5.9 Limited with the factory tow package. Blinking Dash lights and radio and trannsmision/ t-case indicator lights and compass/ temp lights when head lamp switch was in the auto possition and a blinker is on and or the brake pedal is pressed. If the head lamp switch is in any other possition there are none of the fore mentioned lights. So I searched the hell out of Google and tried replacing the switch itself and that didn't work then the BCM and that didn't work then checked relays then got out the meter then checked the fuses. Two of my 15 amp fuses in the passanger side foot area panel were blown. Now I don't know for sure but I do think it had something to do with pulling a trailer that had a shorted wiring harness. I hope this helps someone out. JohnnyCommando8
JohnnyCommando8 is offline
post #7 of 7 Old 04-23-2010, 08:45 PM
99SS-T
Back from the grave
While googling my issue i came across this issue. Which happens to be EXACTLY mine. 5.9 limited that was towing a trailer leads to no parking dash or fog lights.
Putting the headlight selector into the auto makes the radio light dim and undim once a sec. And putting the selector into the parking lights position does nothing. As as if it were turned off totally. No clicking like usual. It appears the original poster has since left the forum so i cannot ask them what they ended up doing.
Hope someone is able to gimmie an idea. Thanks!!
John
Edit. Im a retard. Please disregard. Had to pull all fuses to find the bad one. Surry
99SS-T is offline
98 ZJ, Parking lights flash with factory alarm? NightbaneZ24 ZJ Grand Cherokee Forum 10 05-08-2015 04:49 PM
All exterior and dash lights flash at random times hav24wheel ZJ Grand Cherokee Forum 11 10-07-2009 08:29 AM
Dead blinker & blinking dash lights mjt252 ZJ Grand Cherokee Forum 4 01-26-2009 11:00 AM
Dead blinker & blinking dash lights mjt252 WK Grand Cherokee & XK Commander Forum 1 01-25-2009 06:02 PM
Dash lights and parking lights stuck on..HELP Milan454 ZJ Grand Cherokee Forum 2 02-24-2008 07:52 PM
