No Oil Pressure - help - JeepForum.com
post #1 of 3 Old 03-15-2004, 08:02 AM Thread Starter
JBOWLER
Finally got my jeep fixed for real this time hopefully. Had to replace the Crank Sensor. Now my guage is showing Oil Pressure at 0. If I remember correctly, when the oil is changed they have to hook and unhook that sensor. Where can I look to see? Thanks!
JBOWLER is offline
post #2 of 3 Old 03-15-2004, 08:45 AM
Meerkat
On which engine? Gotta give me something to work with here...
It's just abone the oil filter on the 5.2, and I believe it's just above the oil filter on the 4.0 as well, but I can't be sure since I don't disconnect it on either of my Jeeps to change the oil filter. Not sure why anyone would....
Anyway, hope this helps!
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 3 Old 03-15-2004, 01:32 PM
robbiey19
It is right above the oil filter and it screws into the engine block. I just had to replace mine and it was 22.99 at O'Reilly's. Hope this helps.
robbiey19 is offline
Changed my governor pressure transducer and a governor pressure solenoid but.....? 02Lightning ZJ Grand Cherokee Forum 12 12-21-2009 10:06 PM
Low oil pressure on 5.2 XJ ridebmx ZJ Grand Cherokee Forum 8 04-10-2009 01:47 PM
Oil Pressure shmo ZJ Grand Cherokee Forum 3 03-27-2006 03:25 AM
Low oil pressure on a 4.0 rblahetka ZJ Grand Cherokee Forum 4 03-20-2006 01:12 PM
oil pressure low 2000larado ZJ Grand Cherokee Forum 20 02-26-2006 03:19 PM
