No O/D problem. - JeepForum.com
post #1 of 9 Old 07-08-2011, 11:42 AM Thread Starter
randumbull
No O/D problem.
I have a 97 jeep grand Cherokee 5.2. I changed my tranny fluid and filter and now it wont go into O/D. I didn't mess with anything. I cant find anything on the net so i thought id sign up and ask a question. thanks for the help guys.
randumbull is offline
post #2 of 9 Old 07-08-2011, 01:05 PM Thread Starter
randumbull
please?!
post #3 of 9 Old 07-08-2011, 01:51 PM
KingtheZJ
there is an OD lockout button on the dash. is the light on? when it light is on, the overdrive is locked off
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #4 of 9 Old 07-08-2011, 04:03 PM Thread Starter
randumbull
i know that. like i said, i didnt mess with anything. just did a filter and fluid change.
post #5 of 9 Old 07-08-2011, 04:18 PM
gomes512
1994 ZJ
Going to ask anyways... Are you positive you have the correct fluid level?
Does the O/D light come on when you press the button? Might be that coincidentally the O/D solenoid went bad. Or perhaps it got blocked by freed wear metal after the filter change.
The 42re has the O/D and TCC solenoid as an assembly not sure about your 46.
gomes512 is offline
post #6 of 9 Old 07-08-2011, 05:23 PM Thread Starter
randumbull
yes positive, and the light does come on when i push it, every once and a while when i push it it raises about 200rpm and goes back down. but only sometimes.
post #7 of 9 Old 07-08-2011, 05:34 PM
Blwn89gt
what tranny fluid did you put in?
Blwn89gt is offline
post #8 of 9 Old 07-14-2011, 02:23 PM
jeeponthebeach
Hmm I'm having similar problems. At freeway speeds the 46RH tranny in my 95 ZJ wont stay in overdrive. It'll shift into OD then downshift then shift back into OD then downshift again. It'll keep shifting and dropping out of OD if I keep that speed and RPM. Usually when I'm going up a hill or something. Just recently the light on the OD switch on my dashboard stopped working but when I press the button I can feel it shift. Any ideas?
jeeponthebeach is offline
post #9 of 9 Old 07-16-2011, 04:14 AM
GMV93
2009 WK
is fluid level correct?
GMV93 is offline
Truck wont start...starter problem or engine problem?? 96OCJeep ZJ Grand Cherokee Forum 0 06-26-2011 01:51 AM
is this a battery problem or alternator problem? Lady_Luck ZJ Grand Cherokee Forum 14 01-02-2009 08:04 AM
WJ Heated Seat problem and Mirror Problem JeepPleasure ZJ Grand Cherokee Forum 3 04-10-2008 02:00 AM
Problem with the wheel staus lights on dash and head light switch problem jeep2dmax ZJ Grand Cherokee Forum 0 12-21-2007 07:34 PM
HELP! SOS! 94 GC overdrive problem-Will VSS solve problem tinker1121 ZJ Grand Cherokee Forum 1 07-15-2005 09:08 AM
