no locks - JeepForum.com
post #1 of 7 Old 03-28-2013, 10:12 PM Thread Starter
93zjgrand
no locks
None of my door locks work, when you hit the switch you can hear the relay n the dash, even when you hit the switch on every door, but nothing, locks do not work, it cant be wiring cause you can hear the relay right.
93zjgrand is offline
post #2 of 7 Old 03-28-2013, 10:51 PM
KoreaZJ
1994 ZJ
Both lock/unlock fail?
KoreaZJ is offline
post #3 of 7 Old 03-28-2013, 11:59 PM
dnuccio
lock actuators are probably shot. mine did the same thing. go to a junkyard and get some new ones. bring a drill battery to test them before you buy them.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 7 Old 03-29-2013, 09:56 AM Thread Starter
93zjgrand
I cant be the acuators, cause not all of them could have went out at one time, its jmpossable, yea both lock and unlock failed
post #5 of 7 Old 03-29-2013, 10:03 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
wiring or door module.
ratmonkey is offline
post #6 of 7 Old 03-29-2013, 10:19 AM
dnuccio
I would still test all the actuators individually
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 7 Old 03-29-2013, 05:16 PM
KoreaZJ
1994 ZJ
Check Fuse#14 (20 amp) located in Fuse Block at passenger end of dash.
KoreaZJ is offline
