No hitch mounting studs? - JeepForum.com
post #1 of 19 Old 11-21-2013, 04:59 PM Thread Starter
ZJNewbi3
Bought a used 1yr old hitch yesterday...I go to look under my Jeep and I don't see any mounting studs? I got a picture of one side (both look the same). So how the heck am I supposed to mount this? Do I take out (and replace) the bolts where the studs WOULD be? In my build sheet it says "Trailer Tow Prep-Group" and this didn't have a factory hitch on it, as far as I know.
Just trying to keep her goin'!!
ZJNewbi3 is offline
post #2 of 19 Old 11-21-2013, 07:16 PM Thread Starter
ZJNewbi3
Anyone?
ZJNewbi3 is offline
post #3 of 19 Old 11-21-2013, 07:44 PM
xcaliber81
Pretty sure its a bolt dont think there is a stud just get the proper size bolt.
xcaliber81 is offline
post #4 of 19 Old 11-21-2013, 07:50 PM Thread Starter
ZJNewbi3
That what I'm thinking but every post Iv'e looked up they all had studs...this is weird
ZJNewbi3 is offline
post #5 of 19 Old 11-21-2013, 07:57 PM
xcaliber81
I appear to be wrong there is supposed to be studs, that being said at least 1 of mine broke off from inside the frame and im not sure how im gonna attach the new stud cause it broke lol.
post #6 of 19 Old 11-21-2013, 07:58 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Stock installs do have studs, but they're a PITA to work with. Grade 8 hardware and skinny hands will do the trick.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #7 of 19 Old 11-21-2013, 08:15 PM Thread Starter
ZJNewbi3
So youre saying to take out those two bolts where the stubs would be and replace them then use them to mount the hitch?
ZJNewbi3 is offline
post #8 of 19 Old 11-21-2013, 08:16 PM
somebody5788
1994 ZJ
Neither of my ZJ's had the tow package and they use bolts to hold it on.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
somebody5788 is offline
post #9 of 19 Old 11-21-2013, 08:18 PM
FPKites
ZJjazzyJim
FPKites's Avatar
There should be a plate that hooks to the bumper in there that those bolts go into. I'd recommend pulling the bumper cladding (if you have it) to get the job done right.
The bolt heads look pretty rusty. I wonder what the rest of the bolt looks like.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #10 of 19 Old 11-21-2013, 09:38 PM Thread Starter
ZJNewbi3
So I'm missing a plate? Or are you saying on the other side of those bolts there is a plate so in theory the bolt would go through
Hitch>frame rail>plate your talking about >nut??
Might have to go to the steerlership to figure this one out o.O
ZJNewbi3 is offline
post #11 of 19 Old 11-21-2013, 09:42 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Pretty close - the plate should have the nuts welded to it.
Remove the plastic bumper cladding, then the steel bumper itself. You'll see what I'm talking about
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #12 of 19 Old 11-21-2013, 09:48 PM
xcaliber81
So I can remove the bumper itself and put a nut where the studs are assuming some of mine broke? And it will be sufficient not having the nuts welded? Im curious cause some of mine broke the welded nut inside the frame and a friend suggested cutting into the frame to reweld some nuts but that woukd mean whenever I have to get to my tank I would have to remove both bumpers to drop the skidplate im planning to install.
post #13 of 19 Old 11-21-2013, 09:56 PM
FPKites
ZJjazzyJim
FPKites's Avatar
You need to tread lightly here - from the sound of it, there is more (rust) damage than I've been able to glean from your description.
From a strength perspective, it's always best to have good hardware all over, and multiple layers of steel helps with that. Safety first.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #14 of 19 Old 11-21-2013, 10:01 PM
xcaliber81
Its not that rusty its just those bolts have been there for 19 years and my jeep has almost 500000kms on it and the impact took care of the rest. I think only one maybe two broke like that. But what would you suggest? I dont like the idea of cutting into the frame but it would be a pita to go to that extent everytime I need to drop my tank.
post #15 of 19 Old 11-21-2013, 10:03 PM
xcaliber81
Its just dirt sat on those nuts fora long time and im sure weakend them I suppose. My jeep has undercoating on it from what I think is new. I also dont know about removing the rear bumper and not being able to put it back on cause I broke another bolt. I didnt see an obscene amount of rust when I had my fuel tank off either and a hammer was not able to pierce a hole in the frame either lol.
