no heat ? flush heater core ? - JeepForum.com
post #1 of 21 Old 12-04-2007, 07:24 PM Thread Starter
jeepunlimited
hey guys, my 93 grand cherokee doesnt have very warm heat. It has new heater hoses, new coolant and a new 195 degree thermostat, its leaking a tad bit of coolant from the drain **** but nothing to get in a pinch about.
I am thinkin maybe my heater core is possibley plugged up, what would be the best way to flush it ?? i was thinkin of removing the heater hose lines and using a pressure washer ?? but would a pressure washer cause damage to the heater core?? i dont wanna pull the dash at all...i just want to try to flush it out , i have tried with a garden hose twice, the heat comes back for 1 day good as new, then slowly fades,
any ideas on whats the best way to flush the heater core guys ?
also could the rad cap have anything to do with temp of heat ?? like pressure in the system ?? my dad put a different rad cap on it cause the old ones spring was weak and leaking a tad bit of coolant ?? could a cap be the cause of no heat ??
also the jeep gets up to operating temp everytime i drive it , and there are no overheating problems what so ever.
1993 Jeep Grand Cherokee Limited
Green/Gold, Tan Leather
4.0L , 42RE transmission-- 242 selectable transfer case
Bone Stock with the acception of a K+N drop in filter and my aftermarket stereo, also did alot of new tune up wear and tear parts!
366 000 kilometers and stilll runs great :)
purchased for $125 bucks, amazing daily driver for the money
jeepunlimited is offline
post #2 of 21 Old 12-04-2007, 07:42 PM Thread Starter
jeepunlimited
anybody chime in ?
post #3 of 21 Old 12-04-2007, 08:37 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
With the engine up to temperature, feel the heater hose to see if they are hot. If they are, you are getting a flow thru the heater core & flushing will not cure the problem.
You can flush the heater core via the heater hoses, but DON'T use a pressure washer, or you'll be soaking up water from the passenger's floor, after you blow out the heater core. Use a garden hose & don't do anything that could build up pressure in the system > ~18#.
In my opinion, you probably have an issue with the positioning of your mixing/blend doors. The heater core is getting hot, but the air isn't being channeled into the cabin.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #4 of 21 Old 12-04-2007, 10:17 PM
-Joe-
-Joe-'s Avatar
Are you getting any air flow from the vents at all?
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 21 Old 12-04-2007, 10:24 PM
CLASH
CLASH's Avatar
sometimes my heat/ ac will just randomly shut off then if I let off the gas it will start blowing again. what would cause that?
95 zj, 4.5", 32" bfg at, locked rear.
CLASH is offline
post #6 of 21 Old 12-05-2007, 09:14 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Does it shut off or blow through the defrost?
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #7 of 21 Old 12-05-2007, 10:20 AM Thread Starter
jeepunlimited
i get air through the vents all the time, just sometimes it isnt hot, the heater hoses are burning hot, i cant hold them for very long at all, and they are both hot as hell...feed and return to the heater core
how would i go about checking the doors to the cabin ?? is there a way to open them to heat and leave it on it , like dissconnect the doors soo they cant close ?? is there any way i can work with the doors to get maximum heat out of it , i dont have AC soo im not worried about it , the old owner removed the AC compressor and idont mind not having ac at all, i just want heat!!!
would there be a explanation as to why it wont be that warm but then after driving it for a bit, it starts to heat up the dissapears again when i shut it down and start it back up ???? , would the digital unit in the dash have anything to do with doors not opening correctly ?? or should i dig under the dash to figure it out
also the positioning of the heat doesnt change at all, if i have it on floor, its on the floor, if i have it on defrost, its on defrost , , doesnt move the air flow until the dial is turned
any help would be great
thanx guys
post #8 of 21 Old 12-05-2007, 10:53 AM
CLASH
CLASH's Avatar
it blows through the defrost. what does tthat mean?
CLASH is offline
post #9 of 21 Old 12-05-2007, 11:05 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Vacuum leak
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #10 of 21 Old 12-05-2007, 08:01 PM
CLASH
CLASH's Avatar
ok. how to I go about finding the leak. and how to fix it.
CLASH is offline
post #11 of 21 Old 12-05-2007, 09:22 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Google is your friend Clash - search finding a vacuum leak and you'll find loads of resources.
Search the forum too.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #12 of 21 Old 12-05-2007, 09:32 PM
CLASH
CLASH's Avatar
okkk. ill do some searching
CLASH is offline
post #13 of 21 Old 06-07-2009, 01:25 PM
jeepin4evr
2008 WK
Thread Resurection
Hey Did you ever get your heat problem fixed? I am having trouble with my lack of heat and finding the solution.
_____
jeepin4evr is offline
post #14 of 21 Old 06-07-2009, 03:59 PM
cmonson
Instead of taking the easy way out (dont worry we are all guilty of it sometimes), just replace the 17 year old heater core. It is about 1 days work, but then it will be good for another 15 years.
cmonson is offline
post #15 of 21 Old 12-22-2009, 08:43 AM
jvetter03
So.....I know this is a really old thread, but i have to ask.....what do you do if the previous owner put a few (more than 2) tubes of stop leak in there? ...my buddy is having this problem right now. Thermostat was plugged up, heater core is plugged up...there was even a glob on the back of the radiator cap....WOW..... is there an easy solution to clean all that crap out so that the heater will work again
1999 Wrangler- Locked 8.8, locked D-30, UCF Belly up, 35 Mud Kings on Crager Soft 8's, 4" SL, 2" BB, 1" MML, 1" BL, Adjustable UCA's, Adjustable LCA's, Terra SYE, DC-DS, Smittybilt Tube Fenders, Quick Disco's, Rhino Lined Tub, Neoprene Seats, Marine radio/CB, 4 KC's, Smittybilt XR8[/COLOR]
jvetter03 is offline
heater treater + core + more and still weak heat drwolcot ZJ Grand Cherokee Forum 12 01-30-2010 02:33 PM
Heater Core pigpenn ZJ Grand Cherokee Forum 10 11-12-2009 09:35 PM
Heater Core Filled Only When Heat Is On Or Always? Briandl ZJ Grand Cherokee Forum 5 05-01-2007 07:31 PM
Rad and H/core flush. Eds97ZJ ZJ Grand Cherokee Forum 5 08-02-2005 12:08 AM
Heater core Si_Dude ZJ Grand Cherokee Forum 3 05-02-2003 10:34 AM
