NO heat on driver side HELP!! - JeepForum.com
post #1 of 9 Old 12-17-2007, 12:29 PM Thread Starter
wishweaver
Hi
I have a year 2000 Grand Cherokee Jeep 4.7 Ltr.
Recently the heating started blowing cold on the drivers side but still blows warm on the pasenger side. A few times before this happened when starting the car i could hear water gurggling from somewhere on the passenger side.Both pipes leading to the heating in the engine are hot.Before i take it to a garage and pay out a fortune maybe.could someone perhaps tell me what this may be.Trapped bubbles ?? I need it now as its starting to hit -5 here.
Many thanks
wishweaver is offline
post #2 of 9 Old 12-17-2007, 12:46 PM
Vestjam
I believe this problem is only with the 'Limited' WJ's, but do a search for "Blend Doors" on this site....
It sounds like what you are currently experiencing.... you will NOT be happy with what you read. If it is the blend doors, it is an expensive fix at the dealer because of the time involved to fix it.
Somebody with a WJ will be jumping in here pretty soon to confirm my thoughts...
The girgling is just some trapped air in the system. You can do a search on that also. Usually parking the vehicle on an incline (engine high) and letting the vehicle reach normal temp while the radiator cap is loose will help 'burp' the air out. Lots of other suggestions under the search also
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #3 of 9 Old 12-17-2007, 01:27 PM
Turbonut
Here's some reading. You can check the codes to see what might be wrong:
http://www.wjjeeps.com/climate.htm
Chances are it's the blend doors-$1000 Merry Christmas!
Chrysler should have made an admendment to the owner's manual and sent it to all the Limited owners directing them how to check for the broken blend door.
I realize it's a serious condition, but just annoys me to no end that they manufacture an inferior part(s) designed by an engineer(s) that should be fired, then they want to charge full price for parts and labor to correct their stupid mistake.
Or is it a mistake.........They'll be selling the parts, and if the dealer does the work, more money for them. JUust like the heated seats, etc.
Turbonut is offline
post #4 of 9 Old 12-17-2007, 02:55 PM
mtcox
I just did this repair myself. I was forced into it because the $1000 at the dealer was out of the question. There is plenty of information on the site about the blend door issue. If you're comfortable with turning a lot of nuts, bolts and screws it's a reasonable repair. I think www.wjjeeps.com has the entire breakdown of the job, step by step. Lable everything and place the parts into a zip lock baggie with the corresponding step in the directions. It took me two 8 hour days to knock it out. Good luck.
2001 Jeep Grand Cherokee Limited 4.7L
mtcox is offline
post #5 of 9 Old 12-17-2007, 05:59 PM
cmonson
there is sooo much info on the this board that if you can turn a fastener and follow directions, it is easy. Give yourself a weekend to get through it though...
The alternative is the heater treater. Just search for it. THe other alternative is to make a small hole behind the glove box, and manually flip the door for a temp fix.
I know if and when I have the issue, I will most likely be purchasing the heater treater... The dual climate is a POS anyway. I have 100K miles on my 2000 WJ LTD and no issues to date with the blend doors.
cmonson is offline
post #6 of 9 Old 12-17-2007, 11:09 PM
Briandl
Yeah, that makes a lot of sense...
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #7 of 9 Old 12-18-2007, 05:25 AM
cmonson
it should have been 2 separate statements. When I say it is a POS, it does NOT work well. How often do you really need to change the passenger side air, and when you do, it does not work well.
However, I do have 100K miles and to date have had no blend door issues.
Briandl, if you not contributing to the post, then don't bother posting.
cmonson is offline
post #8 of 9 Old 12-18-2007, 08:48 PM
magneticred
2008 WK
Use the heater treater. It is easy to install and will fix the problem forever.
http://cgi.ebay.com/ebaymotors/Jeep-...mZ270186342949
magneticred is offline
post #9 of 9 Old 12-18-2007, 09:07 PM
manofmany
Holy crap I just looked at the list of people who have bought. He has sold over $10,000 worth of those. I wonder what the cost of production is on a set.
1998 Cherokee 4.0L
1999 Grand Cherokee Limited 4.7L
manofmany is offline
Driver side stereo sound quieter than pass. side mrbell83 ZJ Grand Cherokee Forum 0 05-20-2008 06:45 PM
Seat warmer, driver side, does not heat? ejohn32743 ZJ Grand Cherokee Forum 2 02-20-2008 04:44 PM
99 Grand Cherokee Ltd Heat on passenger side cold on Drivers side. WHATS WRONG?? nosguy ZJ Grand Cherokee Forum 9 12-30-2007 09:15 AM
Heat Works on Driver side only. Thedjgtc ZJ Grand Cherokee Forum 4 02-27-2006 11:12 AM
help!!! passanger side heater vents not as strop as driver side 2002jeep ZJ Grand Cherokee Forum 4 02-03-2005 10:13 AM
