No heat after head gasket change - JeepForum.com
post #1 of 11 Old 12-26-2009, 08:55 PM Thread Starter
Eagle1708
I have a 2000 4.0 and i just changed the head gasket now there's no heat and a viberation at idle but only until i put in gear and drive it, after that it goes away when its back in park or nutural. Its got me pretty stumped so any help will be appreciated, thanks.
Eagle1708 is offline
post #2 of 11 Old 12-26-2009, 09:17 PM
ras2001wj
ras2001wj's Avatar
did you burp the cooling system and top it off?
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
ras2001wj is offline
post #3 of 11 Old 12-26-2009, 10:12 PM Thread Starter
Eagle1708
thanks, i forgot all about that. im still new to the jeep world so please excuse the dumb question, but any ideas about the weird vibration???
post #4 of 11 Old 12-27-2009, 07:57 PM
davets
1956 CJ5
Yep, bleed the air out as far as the heat goes. The vibration however; only a few suggestions. Exhaust leak can cause a vibration but will still have power. If antifreeze got into a cylinder during the job it may have fouled a plug when you started it. This would cause major vibration that would lessen as RPM's go up. Serpentine belt centered on all pulleys? Good luck.
*** 1956 CJ-5, milled head,elec fan,power steering,4-whl discs,rubber mounted cage,all drivetrain and engine incl distributor vented into firewall,Saturn overdrive,Lockrites,Rezeppa joints,2 1/2" springs arched add'l 1 1/2", homemade expanding shackles,reinforced frame,glass tub, stainless tank, 31X15.5 Terras on 15x10 and 15X12 rims-trail, 31X10.5 A/T's on 15X10 alum rims-street,Amsoil.
davets is offline
post #5 of 11 Old 12-28-2009, 08:03 AM Thread Starter
Eagle1708
Thanks alot i finialy got the heat fixedand is good to go , im going to try new spark plugs in a few but it has those E3 plugs in it right now should i go back to just normal plugs???
post #6 of 11 Old 12-28-2009, 09:24 AM
davets
1956 CJ5
I use the stock Champions. They have worked great for me but I don't know anything about the E3's.
davets is offline
post #7 of 11 Old 12-28-2009, 02:21 PM
tirus89
I believe I read somewhere that those E3's burn way to hot for either the 4.0 and 5.2. I may be wrong on that. But the stock plugs always worked great in these rigs.
tirus89 is offline
post #8 of 11 Old 12-28-2009, 05:35 PM
wfttalon
i wouldnt put anything but champions in it, there cheap an work great
wfttalon is offline
post #9 of 11 Old 01-01-2010, 11:06 AM Thread Starter
Eagle1708
Thanks for all of your input!! I figured everything out and she's runnin great. Thanks again
post #10 of 11 Old 01-01-2010, 11:25 AM
baxy
burp the air out of the cooling system and find out where the exhaust is touching the chassis or body, crossmember ect
baxy is offline
post #11 of 11 Old 01-18-2010, 08:51 PM Thread Starter
Eagle1708
Thanks for all of your help. i changed back to champion plugs and it actually runs alot better. Thanks again
4.7l oill fill spout gunk! Head Gasket? Cracked Head? kc8ztw ZJ Grand Cherokee Forum 10 10-29-2009 10:49 AM
Will a cracked head or head gasket...... jpl ZJ Grand Cherokee Forum 2 03-04-2009 08:35 AM
Head gasket going? Jagillac ZJ Grand Cherokee Forum 3 04-26-2007 05:31 PM
No Heat After Changing Valve Cover Gasket.... thomast ZJ Grand Cherokee Forum 1 03-12-2007 02:23 PM
Need to change head gasket - 96GC Laredo 5.2L, Any advice? chriso ZJ Grand Cherokee Forum 0 11-24-2006 01:33 PM
