No gages, tired of trying to fix it - JeepForum.com
post #1 of 6 Old 04-19-2013, 08:41 AM Thread Starter
Devanzj
About 6 months ago I had a ton of troubles with my zj and the only thing I haven't been able to get solved is my gages.
My radio had also stopped working so from what I've read I think its something to do with the power antenna wire. Problem is I can't figure out what I have to do to fix it haha right now there isn't a radio in it
Any suggestions would be great
97 ZJ 5.2L, NP231, 6"ish lift, 33" KM2s, hp30, IRO front long arms, Clayton rear long arms, JKS quick discos, BDS Shocks, Flowmaster Super 10 Series muffler, KOR style bumper
Build Thread -
On the way/waiting to go on: ford 8.8, 4.88s
Devanzj is offline
post #2 of 6 Old 04-19-2013, 10:05 AM
Uniblurb
Uniblurb's Avatar
On the gauges you may want to remove the plastic bezel around the instrument cluster, pull the whole cluster out, shoot some electrical contact cleaner on the plug/receptacle contacts, and re-install to see if it works. If it doesn't try checking for voltage at the dash plug/connector with the key on to see if it has power.
Not sure about the power antennae but on the standard one the wire connects either behind the bottom right passenger side kick-plate or behind the glove box where you may have to remove it to get to the connection. Have seen others where this antennae connection comes loose or goes bad. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #3 of 6 Old 04-19-2013, 11:09 AM Thread Starter
Devanzj
I've tried using a replacement cluster and tested the plug with a test light and it has power. The signal light indicators will light up on the cluster but nothing else
Build Thread -
Devanzj is offline
post #4 of 6 Old 04-19-2013, 12:27 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Test the cluster.
Hold the trip/reset button in, turn the key line you're doing the key trick for check engine codes.
That puts the cluster into self diagnostic mode.
It could be wiring, the bcm, or the pcm.
Do the back lights come on with the headlights?
ratmonkey is offline
post #5 of 6 Old 04-19-2013, 12:43 PM Thread Starter
Devanzj
Ok I'll try that when I get home and no the back lights don't turn on
Build Thread -
Devanzj is offline
post #6 of 6 Old 04-20-2013, 01:18 PM
um7267
im leaning toward a bad ground someone where, or bar contact in the fuse panel
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
