No Front Driveshaft - JeepForum.com
post #1 of 6 Old 10-24-2013, 11:16 PM Thread Starter
timtuttlez3531
No Front Driveshaft
Hey all. I currently own a 95 Laredo, 5.2 4WD. The thing is it has no front driveshaft. Ive been driving it around like this for about 5 months and was curious if this is bad for the vehicle. I don't do any pulling or off-roading at all. My old man was my go to guy for these kinds of things but he recently passed and if I lose this Jeep, I am beyond screwed. Any help or input is appreciated. Thanks everyone.
timtuttlez3531 is offline
post #2 of 6 Old 10-24-2013, 11:26 PM
BoostinBubba
Its possible to damage the viscous coupler inside the transfer case running without a front driveshaft. Damage has probably already been done, though, pick up a $75 case from the pull-a-part when you go to get a front driveshaft just in case.
BoostinBubba is offline
post #3 of 6 Old 10-24-2013, 11:54 PM Thread Starter
timtuttlez3531
Okay. Good to know. Thanks a lot man.
post #4 of 6 Old 10-25-2013, 07:47 AM
WhiteOut
WhiteOut's Avatar
The VC is shot at this point. Your two options are to swap in a 242 or 231 transfer case (thread in the stickies) or replace the VC ($350 part, few hours work). MIght as well leave the driveshaft out at this point, but make sure you are using the e-brake since the 93-95 years will roll in park without the front driveshaft in.
WhiteOut is offline
post #5 of 6 Old 10-25-2013, 11:44 AM Thread Starter
timtuttlez3531
Thanks a lot for the info. And yeah I noticed the rolling a couple times. It's very slight but enough to scare anyone. My parking brake is good but I just avoid hills altogether. Thanks again. I'll have to look into those other TC's at the salvage yard.
post #6 of 6 Old 10-25-2013, 08:06 PM
Mickey_D
I would just change the viscous coupler and put a stock drive shaft back in. With a good viscous coupler (only the 96-98 style is available now I think), there really is no advantage to swapping to a 231 (other than having 2WD for burnouts). The 242 is a horrible transfer case. The Full Time option is really pointless since there is an open differential in it. So all it takes is one wheel to lose traction and you're going nowhere. You then have to shift into Part Time to get moving again. Tell me the point of Full Time now? Plus the 242 is EXTREMELY picky about linkage adjustment. Plus they get stuck in one position requiring rolling back and forth to get them into another selection.
The 249 is stronger, and with a new VC will outlast the Jeep at this point (honestly, do you REALLY think your Jeep is going to last ANOTHER 150,000 miles?).
No modifications to the Jeep required, no getting a shaft shortened, etc.
But that's just my opinion. Take it for what it cost you.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
