No flasher when locking..? - JeepForum.com
post #1 of 20 Old 11-17-2012, 02:41 PM Thread Starter
Shane7
When I go to lock my doors my turn signals don't flash anymore.. any idea why? Also, when I go to lock my driver door it usually just makes a whining noise and doesn't lock. It will never unlock when it does either.
Shane7 is offline
post #2 of 20 Old 11-17-2012, 02:58 PM
Treleaven
I am interested in this. Mine has never flashed so I assumed it wasnt a feature.
98 XJ Auto 4.0L
30x9.5R15 GY Silent Armor
Fender cut n fold
Treleaven is offline
post #3 of 20 Old 11-17-2012, 03:40 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it can be turned on by the dealer. it's a function in the bcm.
automatic door locks at speed can be enabled as well.
shane7, the door lock motor is probably bad, replacing it will likely fix both issues. otherwise the dealer can check to see if the function is still on in the bcm. it's a .5hr labor charge to change features in the bcm. don't let them over charge you.
ratmonkey is offline
post #4 of 20 Old 11-21-2012, 10:12 AM Thread Starter
Shane7
Hm, that's funny, I was having electrical issues some time ago, and I was messing around with BCM. May have been something I did, or when I had it at the dealer when my security system went nuts. I'll probably just leave it be. As for the lock motor, I may just need to get another one. My Jeep is a 98, and my driver door is off a 94. I took the wiring harness out of the 98 door and used it in this door... I may have done something wrong. I'll tear it apart eventually.
Shane7 is offline
post #5 of 20 Old 11-21-2012, 07:43 PM
Nejeep
I thought a horn chirp was the only dealer programmable feature for the door lock, (no light flash) at least on a ZJ.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #6 of 20 Old 11-21-2012, 07:45 PM
MeanGreenZJ
You can program flashing parking lights on WJ's, not ZJ's.
MeanGreenZJ is offline
post #7 of 20 Old 11-22-2012, 04:42 PM
isenior
no flash = problem somewhere
If the lights do not flash they are telling you there is a problem somewhere, maybe one of the doors or the tailgate did not lock, or you put the interior light on with the dash slider and left it on.
Sometimes mine chirps but mostly it doesn't.
ZJ97purpleUK
isenior is offline
post #8 of 20 Old 11-23-2012, 09:24 PM Thread Starter
Shane7
Well, when I bought the damn thing they flashed. They currently do not.
Shane7 is offline
post #9 of 20 Old 11-24-2012, 09:42 AM
Nejeep
The ZJ lights flash for the panic button or alarm trigger, but not lock/unlock as far as I know. Dealer can program things like horn chirp on lock, 15mph door lock, lights on with wipers, single door or all doors unlock with remote, etc.
If someone's ZJ does flash the lights its not a factory alarm.
WJs can be programmed from the VIC to flash the lights on door lock.
Nejeep is offline
post #10 of 20 Old 11-25-2012, 06:19 AM
isenior
My ZJ is stock RHD with factory alarm. The lights flash on lock / unlock. Maybe UK export ZJs were different specification?
ZJ97purpleUK
isenior is offline
post #11 of 20 Old 11-25-2012, 07:10 AM
MeanGreenZJ
Then your ZJ is a ZG. It could be, I know that exports even have rolling codes for their remotes. But as far as the ZJ goes there is no option to disable or enable flashing for keyless entry.
post #12 of 20 Old 11-25-2012, 02:08 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
your factory alarm is aslo different from american spec.
post #13 of 20 Old 11-25-2012, 10:57 PM
Mickey_D
I've owned 3 ZJ's. A 95 and two 97's. Not a single one of them ever flashed any lights arming/disarming the alarm. The 95 and my current 97 were single owners. I asked the previous owner of my current one earlier tonight to confirm and he said the same thing.
ZJ lights don't flash with the factory alarm arming/disarming. If your lights used to flash or still do, it's not a factory alarm.
I've got my original owners manual, I can take scans of it tomorrow if anyone wants.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #14 of 20 Old 11-26-2012, 01:45 AM
ssands85
My 95 has always flashed when locking or unlocking the doors... but I do not have the security system, so maybe that's the difference???
ssands85 is offline
post #15 of 20 Old 11-26-2012, 02:31 AM
KoreaZJ
1994 ZJ
Bought my 94 new. Doors lock, security light flashes, then goes out... nothing else.
KoreaZJ is offline
