No ethanol gas - Page 2 - JeepForum.com
post #16 of 59 Old 04-08-2013, 12:00 AM
Nick05
1987 MJ Comanche
[QUOTE=zander21510;15263140]Only places I've seen E0 is a couple of gas stations in Arkansas in the middle of nowhere and out on marinas in Florida.
hey, you've been through my neck of the woods
Nick05 is offline
post #17 of 59 Old 04-08-2013, 11:52 AM
JPcpa
Just checked price today. 3.889 per gallon at a country store in Va. Regular $3.389 in places but 50 cents is worth it for small engines not sure about cars though.
Wish the mandate would be repealed
2004 LJ, Auto, Zone 3.5"/1.25"BL/MML/285 KO2s
2005 Rubicon
99 Sport
JPcpa is offline
post #18 of 59 Old 04-08-2013, 12:09 PM
exador
1970 CJ5
Its about the same here for either but about 35% of stations here have E0, most people are ignorant and buy what ever is cheapest to save a few cents and don't even know which they are getting.
It does affect mileage about 2mpg, ethenol does burn faster and less efficiently.
check out this article
http://www.fuel-testers.com/expirati...hanol_gas.html
exador is offline
post #19 of 59 Old 04-08-2013, 03:13 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
only place to get pure gas here is the marina, at a 2$ premium over e10.
ratmonkey is offline
post #20 of 59 Old 04-08-2013, 08:13 PM
zander21510
Just found pure-gas.org that lists non-ethanol stations. I looked up the couple I know of in Arkansas but only found one. Sadly no ethanol-free in the metroplex...
zander21510 is offline
post #21 of 59 Old 04-17-2013, 10:15 PM
BLacher
@kensnelling (and others) all MO Hy-Vee gas station's Premium (only) has no Ethanol. I have done calcs and we definitely get more value from it than Ethanol fuels. Plus I am so happy to have for my small engines.
BLacher is offline
post #22 of 59 Old 04-17-2013, 10:23 PM
Nick05
1987 MJ Comanche
if you click on arkansas on that link, the first two are in alma(where i live), next town over(about 8 miles away) has four, the one south of it has 5 or 6 and the one north of it has 1.
Nick05 is offline
post #23 of 59 Old 04-17-2013, 11:49 PM
ZeeJay1997
Try Petro Express or Kangaroo
ZeeJay1997 is online now
post #24 of 59 Old 04-18-2013, 01:01 AM
Football47
I did the math and everything, and it's not worth it for a Jeep... maybe a Prius but not a Jeep.
Can't beat a Jeep
Football47 is offline
post #25 of 59 Old 03-02-2014, 09:22 AM
bhcoffey
Probably wouldn't do much in the Prius. Newer vehicles don't seem to mind the ethanol as much. In reading some other posts about fuel additives and detergents and the top tier fuel recommendations there's a lot to consider on the topic. I typically use Shell most often. Just got the 5.2 XJ in January. Bought it on Empty, and it's a Limited so full console readouts on instantaneous MPG as well as averages, the previous owner had a 3000+ mile average going of 16.2. I reset it immediately and filled up with a local E0 station...about 16.7 mpg (granted we were experiencing FRIGID COLD temps in TN, and lost several points for letting it warmup 15+ min on those mornings.) Jeep needed a few things, so did oil change and tune up (plugs, wires, distributor cap and rotor button with new oil and air filters). Put Shell gas in (87 octane, presumably E10) and got about the same 16.8 or so. ran about 3 tanks of shell in the same range mpg. Added some Gumout complete fuel system cleaner and ran the local E0 in it again. full tank got me 400+ miles and read out about 18 on the in car average, but my mileage app, and hand calculations actually put me at 19.9! Just had new hub bearings put on the front with new axles, replaced the radiator and thermostat as it had been running cold (about 155) and valve cover gasket as it was leaking a bit of oil. On my second tank of Shell since those changes and getting 17-17.5 right now. I do semi-highway driving, it's mostly to work and back about 30 miles 1 way, half is interstate, half is back country roads, no stop and go but VERY hilly and curvy. Gas on outskirts of town is about 3.20, in town where I work and where is most often the convenient place to fill up its been about 3.35, the E0 is 3.55, maybe 10% more if you compare it with the 3.20 I'd have to go out of my way to get. but 19.9 compared to the 16.7 is about 19% increased in MPG, WAY less cost per mile. I'll update once I have the chance to run a full tank of E0 after the hubs/axles/radiator/valve cover gasket work.
Do you guys typically use any fuel additives regularly who strictly use the E0? just curious since most E0 wouldn't contain the detergents and things advertised in the "Top-tier" gas that is E10 if there are things you like (stp red bottle, gumout octane, or the occasional full fuel system cleaners) that you find worth it as well?
bhcoffey is offline
post #26 of 59 Old 03-02-2014, 11:27 AM
StPaul59
Not worth it. Coundnt see any gains from it. I have tried it a few times. The station closest to me now charges 4.69 per gallon for non eth.
StPaul59 is offline
post #27 of 59 Old 03-02-2014, 12:21 PM
bhcoffey
Wow, that's ridiculous. Yea that wouldn't be with it at that markup...like I said this is my first jeep, but had a few 2000 and older gm trucks/SUVs and seemed to be pretty common for me to see 10-20% increase in mileage, and seeing about that so far.
bhcoffey is offline
post #28 of 59 Old 03-02-2014, 12:52 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
I run E free 93 in the niner. It's pretty easy to find in SW VA.
Sent from my iPhone 6 using JeepForum
In the garage: M1 4bbl
McCloudsZJ is offline
post #29 of 59 Old 03-02-2014, 01:16 PM
greyhnd
Kind of a weird thing here where I live. The station where I buy my fuel is ethanol free in all grades, the station directly across the street sells ethanol gas in it's "super" gas which is always priced the same as the regular fuel I buy.
The pumps there I buy have no notification of ethanol added on them. Just the opposite across the street. The ethanol added station always has more vehicles at their pumps, or so it seems when I drive by. I wonder why that is?
greyhnd is offline
post #30 of 59 Old 03-02-2014, 02:00 PM
Nick05
1987 MJ Comanche
most people don't care if it runs worse off of it, all they see is that it is cheaper, but it is a short term gain because they will have to fill up more. the only thing i do is every once in a while i will run some lucas through the system.
Nick05 is offline
