No delay in front wipers-ZJ - JeepForum.com
post #1 of 1 Old 05-07-2009, 12:41 PM Thread Starter
95ZJ_PA
Hi and Lo speeds only on front wipers, and washer spray works, but not the 3-swipe delay when washer button is pushed. (blades DO return to stopped position)
Searched here and found several similar issues, and micifus' post on the Wiper Module fix (great pix and instructions!) - tried it but no change. Found a used wiper module on ebay, swapped it today, same results. (Hi/Lo ok - no delay).
Given 2 different modules (BTW - 2nd, ebay-purchased one already had the wire trace solder fix done to it) and same results - could this be the multifunction switch? Has anyone else tried the solder fix but without success? That seems to be the "standard" repair here - so not sure if soldering skills are at fault, or if there's a possible, secondary solution. Don't want to spring for a new MF Switch if not needed - thx.
95ZJ_PA is offline
95 zj delay on wipers does not work coopdc78 ZJ Grand Cherokee Forum 16 01-10-2010 03:16 PM
ZJ Delay Wipers Inop Kota04SXT ZJ Grand Cherokee Forum 1 02-01-2009 10:51 PM
Wipers won't delay. -Joseph ZJ Grand Cherokee Forum 3 12-04-2006 05:19 PM
Delay setting operates wipers low, and wipers stop in random position when turned off Hubjeep ZJ Grand Cherokee Forum 1 08-10-2006 10:41 PM
question about delay wipers jerryhipp ZJ Grand Cherokee Forum 4 03-05-2004 04:28 AM
