No dash lights or tail lights - instantly blowing fuses - JeepForum.com
post #1 of 3 Old 10-31-2007, 09:03 PM Thread Starter
oxrageous
I have a 94 GC. A few months ago I tore the dash apart to replace the evaporator core. Upon putting everything back together, everything worked for a couple of weeks. Then, one day the dash lights didn't come on. Also, the parking lights and the tail lights did not work - the headlights and brake lights work fine.
Upon checking the fuses, I found fuse #12 was blown, which was for "Parking lamps, automatic headlamps". I replaced the fuse, then turned on the lights - bam, instant blown fuse. Tried it again, same result. Pop!
Before I tear the dash apart looking for connections, does anyone have any advice ahead of time? What would cause a fuse to instantly blow? While the dash lights and tail lights seem to run on different fuses, I've read about other people having both problems at once, so they must be connected somehow. Any help would be appreciated.
oxrageous is offline
post #2 of 3 Old 10-31-2007, 09:14 PM
bbehnke
theres a short in the wires kinda like two wires touching together and it will cause a short in the system and its safty is to blow the fuse so thats whats happening. as for fixing it... short of taking it all apart again and checking connections im not to sure how to fix it.
2001 WJ I6 selec-trac
64,000 miles
accessories: manik brush gaurd, KC daylighters, 2" BB w/ rusty's shocks, Dueler A/T REVO 245/75/R16, mudflaps, tow package, 1.5" wheel spacers, kevins exhaust, and an AIR HORN!
RED JEEP CLUB #424
bbehnke is offline
post #3 of 3 Old 11-01-2007, 08:00 AM
BLACKzj52
that happened to me, but my BCM was f-ed up.. cost me $350 to get fixed...
but mine was a lil different than urs i think..
BLACKzj52 is offline
Courtesy Lights keep blowing fuses 99 GC 4.6 pontiacuser ZJ Grand Cherokee Forum 0 01-13-2009 06:12 PM
Dash comp flashing tail light fault- but lights work??? Loki702 ZJ Grand Cherokee Forum 4 10-28-2008 07:19 AM
Tail lights out, blows fuses Limited98 ZJ Grand Cherokee Forum 3 10-21-2008 03:24 PM
tail lights went out, now no power and dome lights buzzing tigerlilly ZJ Grand Cherokee Forum 1 09-25-2008 01:08 PM
Altezza tail lights/Dash trim kits haus409 ZJ Grand Cherokee Forum 36 03-08-2005 05:32 PM
