No codes, no overdrive - Page 2 - JeepForum.com
post #16 of 18 Old 06-28-2012, 06:21 AM Thread Starter
Moogs3840
The thermister is not the same design and has a different wiring harness. That's why I didn't just put the original one from the ZJ in the WJ tranny. I have decided that I will wire in another 1k resister in series to the one in already put in, that will make the resistance the computer sees almost right. As heat increases the resistance will be close. when I first wired in the 1k I was not think right so after JS97ZJ said what he said I pulled up the formula and laughed at my mistake. It may have been a blessing because when I pulled apart the over drive unit, I laid everything out in order but had to wait a few days for the output shaft to come in and during that time the wire ring, wave ring, and reaction ring got mixed up. (was apart at my work) so going back together the layout was wire ring, wave ring, and on top reaction ring. Totally wrong hahaha. So having it not engage is a good thing. At this point I know what I did wrong and will correct it this weekend. Will let you know when done.
Moogs3840 is offline
post #17 of 18 Old 07-03-2012, 02:16 PM Thread Starter
Moogs3840
Yesterday I added the resistor in series to the other resistor and corrected the snap rings and wave plate order. Got overdrive, works great. I will add an aux cooler to the transmission cooler flow, just as a fail safe.
post #18 of 18 Old 07-23-2012, 07:17 PM Thread Starter
Moogs3840
just an update, Transmission shifts great. installed a Dana 30 front axle. 4 wheel drive works great. Very good cheap build.
42re , od , overdrive , wj , zj
NO Overdrive, no codes, 94 Grand I6 res0n0xg ZJ Grand Cherokee Forum 12 07-23-2012 08:06 PM
Fault Codes, DTC Diagnostic Trouble codes ETC. ef1992 ZJ Grand Cherokee Forum 4 07-16-2009 01:59 PM
2K WJ not running right with fuel inj codes & No ASD relay output voltage codes. HELP hillside250 ZJ Grand Cherokee Forum 0 04-06-2009 02:17 AM
TCM P0750...codes and more codes and the one speed tranny Mattt0305 WK Grand Cherokee & XK Commander Forum 3 11-01-2008 09:50 PM
6 Codes... New to codes and Tranny issues jakewalczak ZJ Grand Cherokee Forum 6 02-06-2008 07:32 PM
