-   -   No A/C at sea level??? (http://www.jeepforum.com/forum/f13/no-c-sea-level-1549766/)
ZJfamilyfun 07-16-2013 02:14 PM
So our A/C has been working all summer long. Nice and cold. Then we left the springs (6,600ft above sea level) at night. a/c off. Then the sun came up and so did the outside temp. We were in Kansas / Missouri at this time. So i turned on the a/c. Nothing. Just blew air. Not cold air. All settings worked. Defrost, vent, floor. All blower motor speeds worked. Just no cold air. What gives? Does altitude play a roll in this? Density of the air? Humidity? Or just coincidence?
Oldfrog 07-16-2013 04:31 PM
Check to see if your AC clutch is engaging. It might have a slow leak ( I can guarantee it does...even if it's a tiny bit because they all do.)...and it maybe has leaked out enough r 134 so that the clutch will not engage. If so, you'll need a charge to top it off...which you can do yourself....if you jump the cutoff switch so that the compressor clutch engages again while charging it.
ZJfamilyfun 07-18-2013 12:58 AM
Clutch is engaging. So im guessing its low. Low enough to operate at high altitude but notsea level.
kodenz 07-18-2013 10:09 AM
Haha I actually have the reverse problem
I just got a recharge a few months ago
I live at a few feet below sea level, and when I got up to about 5-7000feet I lost my a/c until I got back home
Sent from somewhere
dellis 07-18-2013 10:59 AM
Altitude (or air pressure) will not cause your system to suddenly stop working. It is a closed system, under pressure much higher than atmospheric.
However, temperature differences might play a role in your system if your coolant charge is close to the shut-off limit.
The time now is 03:19 PM.
